Tudor--a fake??
1 hour ago, Nucejoe said:
Usually Tudors indicate Chronometer on the dial
Depends on the model.
Looking at the Tudor website the model ranges that do not state "chronometer" or "officially certified" are the Ranger, Tudor Royal, 1926, and Clair De Rose.
LWS's watch looks similar to the styling in the 1926 range, although the current range appears to feature at least some numerals on the dials, I can't see one that is batons only, so the jury is still out.
Why not to glue a M10-Nut with Cyanoacrylat (Superglue..) to the back,
afterwards it should be possible to unglue with Acetone, this was the Solution
for some Cases as reported in this Forum. Or else buy a 5537-Clone Set from China......
regards,
Ernst
regards,
Ernst
That is a great method which have used. But I have never used it for reinstallation.
So, is the oscilator in above models  COSC certifed chronograde ?
Thats the $200  question.
19 hours ago, LittleWatchShop said:
I need to get a tool to open these, but I don't want to spend real money...any ideas
I've seen people claim that the ball used for removing screw backs can remove Rolex backs but if the back is on really tight you do need the tool.
Another thing the use rather than superglue is epoxy. The interesting thing with epoxy is that if you drop the back a pot of boiling water then there is no problem taking off whatever's glued together. I learned that trick from the material house the used it before removing crystals that were  epoxy  in the epoxy basically gets soft.
Listen to the heart.
 A low grade ETA  balance complete can be fitted into  a Chrono grade Tudor, but the Tudor  then runs only as good as a $400 west end watch.
The tg print out you posted is a poor listener and analyzer, yet I believe you have a genuine Tudor.
On 2/4/2023 at 2:20 PM, LittleWatchShop said:
I got in trade for a clock repair. I put about $50 worth of parts in the clock
So, with a little more data, I will be convinced that it is genuine.  I will give it back to the guy I made the trade with.  At the time, I thought it was a copy and so did he.  He was kinda clueless, so whatever he thought about the watch is not a data point.
4 hours ago, LittleWatchShop said:
Yup.  Its the real deal.  Has an ETA 2824 movement.
Haha,
I want a thums up from nicklesilver on this one.
    • Maybe I'm over simplifying this and I'm a little late to the discussion, but just by my looking at oil when I use it on a treated cap jewel  the oil stays in one nice bubble, but when I don't it spreads out to the edges of the jewel. I'm not sure (but could well be wrong) but the analogy of a waxed car and rain is accurate in this case, the wax is very hydrophobic and repels the water, however, the process epilame works by is a different physical process based upon cohesion/adhesion (oleophilic) not repulsion (oleophobic)  at least as far as I have read/observed. If one were to use a oleophobic substance equivalent to wax (hydrophobic) then one would need to create a donut shape to fence in the oil, however if one used such a strategy with a epilame which is oleophilic then the oil would sit on the ring of the donut and not in the 'donut hole', exactly where you don't want it. Even if the oil is smeared then the oleophilic epilame should pull it back to the center (see diagram below). Reference
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
    • Latest 404 is this Baron which has a copy of a Seiko 66B movement in it, handy when I needed to find a replacement setting lever. Apart from the setting lever, crown, stem and new crystal (original was cracked) the watch is original. Finished result:
