How can the cannon pinion gear be widened to reduce friction?
By djwilliams37 · Posted
There are plenty of 8n24 movements available but I think they are all Chinese copies. Most have the name Myota Japan on them but ship from China. Are these if copies worth purchasing? The prices vary from £20 upwards -
I know that many people have had this happen to them, but strangely, even very strangely, I never have. I always get a lot of weird things that nobody else gets. Anyway, I always use the tip of brass tweezers to remove the stem. I pull the crown out and while I keep pulling the crown, I gradually press the button harder and harder until the stem releases. Maybe the next time I'll get in trouble, so knock on wood. I got used to using tweezers as I couldn't get it to work with a screwdriver the first time I serviced an ETA 28XX movement.
Those scribbled numbers mean nothing they are repair numbers. Repairers have there own code. It is not good practise. watchweasol is right we need better photos and also some of the case.
