29 minutes ago, Tiny said:
Has anyone got a good automatic watch I could buy to get me on my way or even just the movement.
Why it has to be an automatic? Just because that's what everyone wants, to service and then wear it? What we're trying to convey here is that watchmaking isn't easy, learning takes patience, application and some money, and it must be separated, at the beginning, from working on watches that you are proud to own, heirlooms, valuable pieces, ladies watches, Chinese watches, etc. Seems a too long list? Please have a read to the topic I had linked above.
I will also try another way. Please take a no value quartz watch, even broken. Take it fully apart dow to the smallest screw and bit, then put it back together, the best way you can. Then let us know if you found that easy, or pleasant, and what you think the experiment has taught you about having a normal stepped up approach to working on watch movements.
On 3/3/2022 at 7:36 PM, Tiny said:
the photo's a very low quality I have taken some more but I'm unable to add them in a post but rather add as a attachment at the end of the post.
Just noticed this. Please read the first post of the topic below. Note, the plus sign in the thumbnail may be 'Insert' instead.
On 3/6/2022 at 8:14 PM, Tiny said:
So I'm ashamed to ask Has anyone got a good automatic watch I could buy to get me on my way or even just the movement. I do have the fossil with TY2724 but it's a watch I would like to repair and use/sell on
If this sort of post is not allowed please delete
Are you in the UK? I could probably post you something.
Thank you Rob I have some material sent by a very kind member of this forum received today.
But thank you for your offer and yes I'm in Warwickshire, UK
That's just the opinions of Timex haters. Timexes are built differently but are most definitely repairable.
There are screws under the rotor to remove the auto mechanism. You'll need to rotate the rotor and access them through the two holes in the rotor.
Timexes are very unconventional. For someone trained on Swiss movements, they will find them really frustrating as they will tax their patience and insult their intelligence.
Timexes will look terrible on a timegrapher but will keep reasonably good time.
But I would advise you to start on something more conventional first. There are plenty of affordable pre-owned watches on eBay. I would even recommend brands like Seiko as their parts are easily available.
Tiny - see how you get on with what you were sent. And if you need something else then let me know and I’ll bung something into an envelope.
  • 4 weeks later...
Hello again all need advice.
So I'm getting ready to service my ETA 2824 Movement. But using the square movement holder I find it easy to tip over and also if not placed in the right place can damage the movement so I want a holder that is better and more stable I was just wondering if this holder is betterHa595b0f32f704b1481d3890797116cedO.thumb.jpg.df7743b360762351d86a66fc11e68144.jpg
For a noobie to work on as it's quite a small movement. I am waiting for new parts to arrive from ebay (watch date wheel) but I don't know if there is any other damage yet as if not opened it up yet.
this is my current holder.
I've only ever used the Bergeon 4040 for all my movements. It will easily hold a 2824 securely and without damage. Is you movement holder smaller ?
But, as @watchweasol points out, £3.75 for a Horotec is good value.
Mine is a ebay knock off and is NOT double sided so I have gone with the green one suggested and small update date wheel has arrived whoop
It's worth investing in the Bergeon holder - that, screwdrivers and tweezers are the three things worth spending more money on.
Even cheap movement holders can be improved. This is a cheap movement holder which I modified by adding a spring washer and filing the jaws deeper.
The spring washer maintains pressure even when there is slight movement of the plate, reducing incidents of pop outs.
The deeper jaws grip the plate better.
The only thing I haven't solved is how to grip plates with cutouts where the jaws are located.
Yes, it is. No matter who makes it, an universal holder can't grab firmly, becuase the contact surface is small and one can't and shouldn't tighten much.
That being said, when a mov.t slips out of the holder the most to blame is the operator, pushing on a side without balancing with pegwood on the other, or general clumsiness. You can do well with a plastic cap, or poorly with an expensive dedicated holder. As with any tools, it depends on how you use it.
to clarify something attaching a PDF. The problem with the 4040 style of movement holder at least as far as photographs go it looks almost identical to the 4039 movement holder at least casually.  if you look in the PDF there are actually specifically different sizes. The other reason for the PDF is other movement holders?
in the PDF there's something called a reversible movement holder with knob . Also found at the link below and I have a picture attached you can see what it looks like. notice the holders are designed for specific sizes only. The reversible aspect is the holder is designed to hold one side or the other side of the movement you're working on.  then the reason for the knob is really more of a push button push it in it opens up the holder can drop your movement in and that it holds a really secure.
https://www.cousinsuk.com/product/by-size-bergeon-5914
7103 A B C D movement holder types.pdf
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
