You can add images to your post simply by using the "Click to choose files" link which you will find below the post editing box. If you do not see the link then use the "Drag files here to attach, or choose files" function which is found at the bottom of each edit box. You will also find a drop down menu to the right of the editing box "Insert Other Media". From here you can use an attachment you have previously uploaded in another post, or you can insert an image from a URL on another website o
