1968 Bulova Oceanographer case back removal
tarrda
I bought this watch in 1968 and am interested in getting it running again. It is a "t Swiss Made t", it has tritium dust inside the case and the second hand has rust on it. I wanted to open the case back and see if it has rust inside but can't figure out how. I've already scratched it 3 times and figure I can polish that out but I quit until I know what I am doing. Can anybody help. I thought it was a press fit and would just pry it off but their isn't any space to fit any tool. I used a Bergeron pry tool but again, it won't catch any where on the case back. Any help would be appreciated. Also if you know of a watchmaker that might be interested in tackling a service on this let me know.006.thumb.JPG.9633c9e2b2c3b13b3a08bfdb193580ec.JPG this one let me know.010.thumb.JPG.9cdda9ed63d4d85c760b4847850036c8.JPG
Edited by tarrda
misspelled words
I think I can see a little tab sticking out of the caseback, around the 2 o'clock position. That is the place to insert the caseback knife.
Opening a caseback is no so much a prying action but a wedging one. My preference now is a Seiko style knife. It is a short stubby blade, more like a chisel and is pushed with the palm of your hand, rather than your index finger.
If the watch has be worn a lot, rust, sweat and dead skin cells could have collected in the cracks and seized up the caseback. I like to use a wet toothbrush to clean up the case first, to wet and soften any organic matter. This also prevents debris from getting into the movement once the back pops off.
Try these tricks first. If it doesn't work, then we'll guide you through level 2 opening. 🤣
I'm tempted to think this is a one piece case because the writing on the back is prefectly centred!
The usual way to get into these one-piece case is to apply force on the crown but on some there will be a release that is visible with the crystal removed.
Anilv.
I suspect it is a really tight snap back case back. You might need one of these because when really tight scratches and un necessary marks can happen with a case knife.Also when re fitting a case press of some sort will be needed to re fit.
  • Similar Content
    • I've started trying to use the Betfit, but I don't know which measurement I must take for the caliber. The diameter of the dial side is 40mm, and the other side 36,5mm 🤔.
    • I'm currently 3D printing a new basket and trays for my Pearl machine - I printed one last week in PETG material and it worked well at first. I had taken a calibration cube and soaked it in old cleaning fluid for 8 weeks and then measured it, and there was no discernable swelling or shrinkage and the cube seemed mechanically intact. All went well after the cleaning cycles and then onto the drying cycle..... that's when things went awry. The heat was more than I was expecting and the basket and individual trays warped and deformed, I later found out that PETG is rated to 65°C working temperature (PLA = 54°C) I am now trying to print from nylon (working temperature = +/- 100°C, depending on the specific blend) - but it is extremely difficult to print with, my third attempt is chugging away now while I am at work - hopefully I don't go home to a ball of wool like last time!  Assuming the heating compartment can't go higher than 100°C.... but not second guessing myself...anyone have any ideas or measured it? I also have a question on the trays, maybe I'm not seeing the obvious, but how do you use the ones identified with the arrow? they are called  Basket_for_large_mainplate_and_mainspring.stl Basket_for_small_mainplate_and_mainspring.stl I can see the place for the mainplate, but how are you supposed to place the mainspring, you can't uncoil the mainspring to fit around the outer circumference of the tray or else you would damage the inner tight coils. Is the idea that you supposed to lay it on top of the mainplate?
    • It is possible to true the pearl basket to run better takes a good hour of filing though.
    • Yes, the general pat is this. On my diagram the points where the springs rises and levels are marked with red circles. This is only to show on all pictures (the ones that doesn't show this points as they are seen only from aside, not from above) where this points are. On You pictures, the pont where the spring rises is not marked. The point where it levels is marked with A. The point B is where the change in radius should start, but there is sharp bend there which should not be that sharp.
    • I agree, very minimalist dial,  but then the diamond. The 1973 R has a black dial and gold case and is similar in layout. But on the MyBulova site there really is nothing else like it...
