From what I have seen a read on this there general consensus seems to be with manual wind watches a thin coat of 8200 along the length of the spring, both sides, unless it's a new spring which should already be lubricated. Then something like D5 or 1300 were the arbour rotates in the barrel, some also but a couple of drops of oil/grease on the bottom of the barrel and some put some on the top of the spring before fitting the lid of the barrel.  I suspect only the spring and arbour need lubrication the rest is just down to the individuals technique.
36 minutes ago, Nucejoe said:
I don't understand why mainsprings should be lubricated along its length.
There's friction between the coils as it winds and unwinds. You can see the wear spots easily on old blue springs, and feel them on modern springs.
  • 4 weeks later...
Ok, folks; all this discussion and I’m still curious about your position on this question:
does this mainspring require any lubrication? It’s a white alloy/not automatic, but doesn’t mention it is pre-lubricated. Of course, it is made to be directly inserted into the barrel…thoughts?
Edited by Woolshire
What do you think, can this be used as braking grease? [On a scrap movements for practice, not professionally] It is Molybdenum Disulfide grease for for extra long lubricity and high pressures. It has the same color and consistency as Kluber Chronogrease P125, and the main ingredient is MoS2, just like in P125. I am just curious, please don't rant at me 😄
Edited by Kramm
  • Kramm changed the title to Alternative braking grease?
I would put it into the barrel straight from the holder, then put three big spots of oil onto the coils to wick in. If it is pre-lubricated you won't be over-oiling, so no harm done. It definitely needs lubrication, and I suspect it is old stock, so even if pre-lubricated, it is probably quite dry by now.
11 hours ago, Klassiker said:
I have no idea, but I am looking forward to the results of your experiment!
I have tested LM-47 grease on an old Vostok 2416B automatic movement. The grease is thick and it really nicely adheres to the barrel wall. Under pressure from the mainspring, grease liquifies and because of that, it probably sticks the bridle to the barrel wall, not letting it slip until the very end. My conclusion is that this grease has good braking properties, and MoS2 should protect the barrel wall from wear. The only question remains how long will it last...
Langzeitfett - should last a long time!
Seriously, if you get the specified power reserve, and it doesn't spread everywhere, especially outside the barrel, then I don't see a problem with it as a cheap alternative for your own watches. If you remember, give us an update in a few months.
22 hours ago, RichardHarris123 said:
Can't find any concensus
In addition to the million articles, you read the previous 12 pages of this thread, right? What makes you think you will find a concensus here? 🙂
What specifically is troubling you?
  • Haha 2
  • Sad 1
The lubrication of clocks and watches is a contencious subject.  I should seek out the articals by Mark Lovick or Nicklesilver who are the professionals and do it for a living. As you have found out there are lots of opinions.     good luck.
I don't see any contention at least on the specific subject of this topic. Virtually every other page contains the same sound and proven advice by our known best contributors, and others, all saying basically the same. If anyone thinks that's not the case, can go ahead and summarize about what exactly people does not agree on.
Thanks. I agree it should have some oil added. For this case, still 8200 or, maybe a little HP1300 on the coils?
Also, this NOS white alloy mainspring is likely 55-60 years old. And I’m still curious if this one would have been lubricated as made? Or did they expect watchmakers to snap into place and then oil coils as described?
Edited by Woolshire
8200 or HP1300, or any number of alternatives will be fine. It depends a lot on what you have to hand. Re the White-a-loy spring: If it doesn't say pre-lubricated on the packet, then I would guess it was supplied dry. That really is a guess though. There are traditionally two ways of applying oil; uncoiled and wiping with oily paper, or coiled, with drops applied to the barrel surfaces and coils. As the older blue steel springs had to be oiled by the watchmaker, I'm guessing the old methods prevailed, and only later was pre-lubrication accepted and widely adopted. I'd like to hear what the "old pros" say about it though.
Edited by Klassiker
Hi all.
A quick question I hope regarding braking grease for the mainspring barrel wall.
Moebious list 3, 8212, 8213 and 8217.
The first two I think I understand with 8212 offering week braking for alluminium barrels and 8213 offering strong braking for brass barrels but then we have 8217 listed as anti sliding for large barrels and providing powerful braking.
When would I have to use 8217 instead of 8213.
Thanks in advance to anyone who can clear up my confusion.
As an added question kramm, would you use this on the barrel wall only and leave the rest of the mainspring unlubed?
I see Mark recomends the 8217 is this better than 8213 for all watches, when would one be better than the other.
Sorry I am new at this and getting myself confused.
Do you also apply grease to the rim of the barrel in a manual wind watch or is it only in Automatics.
Just watched a Cronoglide video on youtube and Kallie used 8207 which is a graphite grease on the barrel of a Rolex he was working on but we didn't get to see if it was a Manual or Automatic.
Thanks for any help with this.
Paul
Edited by Paul80
@Paul80I guess my question to you is: what are you working on? Is it a practice movement? Is it an heirloom antique given to you by a relative with the admonishment not to mess it up?
I'm completely new to this. I still have my first movement in pieces waiting for my oils to arrive.
I routinely have been watching three individuals on YouTube who do nice work (one of whom claims to be a novice hobbiest). I have seen felted tweezers advertised as being used to wipe a mainspring with something prior to winding it into a winder and loading it into a barrel. I have seen braking grease applied to the barrels of automatics. I have seen three drops of (something) applied to the bottom inside of a barrel prior to installing a spring.
I think the current crop of Swiss manufacturing house have very intricate and detailed lubrication specs. Some of the new, synthetic lubricants behave differently under pressure. What might have worked just fine on a 100 year old pocket watch 100 years ago will likely still work on that type of watch assuming that you do in fact service it at the same interval used 100 years ago. These days service intervals are longer than they were. If you're working on a historic piece of value I'd suggest that you rethink your ability and work on something less valuable.
I want to open up my hand wound Zenith but I want to gain experience with several older and newer movements before I tackle that.
If you look closely at the 22 page Moebius oil description document you can see what the viscosity is of each of their oils at various temperatures. I doubt that using D5 in place of HP1300 in place of 9104 would impact the functioning of a watch. It's not clear to me where one would use molykote dx in place of D5 but they are noted as being similar by some.
You might get a better result if you privately asked your question of one of the folks on the board whom you respect for their answers. You might also think about if it really matters for what you're actually doing at the moment.
I see you've come away from the mayhem Gary, it was doing my bloody head in . Personally I think there are too many variables  for even the pros to agree with each other. Some are helpful and some want to wave their  school reports in front of your face and argue that their ways are the best. There is such a vast amount to learn but you need to start somewhere, when you finally get going, a lot will fall into place. The confusion  does die down and you will honestly  figure things out for yourself. But some re organising of the posts on basics needs to be done, I've found posts going back 8 years. A decent section outlining the basics of tools and equipment is already there but maybe needs to be elaborated  on. And in my very honest strong opinions on certain behaviour, that definitely needs addressing. I hate bullies.  How's it going anyway, has you bits arrived yet ?
14 hours ago, Neverenoughwatches said:
Nah mate. I think some are just fed up of talking about the subject tbh. How much if a beginner  are you?
How much of a beginner, less than a year so very much a beginner.
I have been using 8213 but keep seeing reference to 8217 being the grease of choice including Mark of WRT fame, then I saw Kalle from Chronoglide recomending 8207 Graphite Grease for Braking so was wondeing if I had made right decision with 8213
My other Lubricants are quite basic, 9010, HP1300, 941 (I have not encountered a high beat watch yet but do have 9415 for when I do) 8200, 9501 & 8212 & 8213.
Currently I am only working on Japanese watches, Seiko and Citizen.
Should I move to 8217 instead of 8213 and were does 8207 fit in, is it a braking grease (Its not listed as such by Moebious) or is Kalle just using as such.
Paul
Paul
Hi Paul you're  about the same as me than . Haha. Sorry my friend I've not gone that deep into oils, you're way above me there. I try to keep things simple and stick to 4 oils only maybe another needed but that's as far as I want to go. I never see the point of overcomplicated things for my self. I think you could tell me more about oils than I can you 🙂. There is always a lot of discussion  about the subject. It's best to just pick one pro and stick to them, but they can get arsy when asked the same questions over and over. If you read back a couple of posts you'll notice my post on that. Have a quick look through back posts to see if your answer is there first. There is one member  on here that is apparently good with seikos. Ask vwatches i think he knows who he is.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
