Omega 55* seconds pinion oiling
JohnC
Hi folks,
I am working on an Omega 552. The basic movement is together and running fine, but I now have to add the seconds pinion, which is held in place with a small spring.
I have been told elsewhere not to oil the back side of the pinion, where it contacts the spring. OK, but how about the bushing side? Can anyone advise about this? I know at least one person here has posted about the 500 series before, but I cannot find the thread.
I have found documentation for this movement (or, to be precise, the 551 - which I believe is just the chronometer version of this), which discusses the automatic works in detail but does not give advice about base movement oiling.
Many thanks in advance.
Edited by JohnC
Typo
I wouldn't listen to whoever said that ?  and oil & epilame.
35 minutes ago, JohnC said:
Hi folks,
I am working on an Omega 552. The basic movement is together and running fine, but I now have to add the sub-seconds pinion, which is held in place with a small spring.
A sub second pinion on a 552?
Forgive me, but I thought this was a centre seconds sweep second movemnt?
One of the problems we have with this is Omega is not entirely helpful. If you look up the 552 they will refer you back to the 550 and if you download the tech sheet it's only the parts list. Then unhelpful it refers you to another document where they group all the common things together. But that does not have lubrication of the basic caliper only specialty items and this is not considered a specialty item.
One of the problems subjects like this are hard to find on the discussion group of fast discussion is how would it be titled? I know we have discussed it before just not finding it. Also the other problem is there are variations to this part. In other words some of them have an upper pivots in a jewel which you probably would lubricate but would you lubricate the spring for instance? So conveniently are not finding anything at all.
363_Omega 550 NewLR cousins UK.pdf
Seem to remember that the spring should not be over lubed.  i gather there needs to be some friction to stop it overrunning as it ticks over but not too much to make it judder.
I have a note from somewhere I can't recall where (possibly from Cal 1022 which apparently may be similar to 550 as scribbled on same piece of paper!!), which states,
"Adjust it (the spring) so that it has enough tension that once you lift it. the gear train spins just a little but not too much when the pallet fork is out.  You want the centre (second?) wheel to turn about about half a rotation when you do this. You want to get crazy,  epilame those two parts (spring and pinion) and a little 9010 will keep you out of prison",
Wording in brackets is mine not in the original note !!
Hope this helps a little.
Edited by canthus
I had the same dilemma with my cal 565. I ended up putting the tiniest smear of oil (9010) under the spring.
I hate those springs - very easy to accidently bend, and then break, trying to get the correct pressure on the pinion. And of course, being Omega, not cheap to replace.
Too little pressure and the second hand judders, too much and it kills you amplitude.
@canthus your past self was wise to write that down! Many thanks. @mikepilk yes it's a slightly annoying system - going to be more so when I have to put the seconds hand back on. @JohnR725 yeah, the documentation is pretty obscure on this point. What I am hearing here is lube both sides with 9010 very lightly. Seems like the right intuition to me. If I hear differently I will let you guys know.
From a respected (WOSTEP) authority: low-torque oil on the bushing side, no oil (or extremely light) on the spring side. The spring should be tight enough to gather (hold up) 1-1.5 turns of the fourth wheel when the pallets are removed and you wind the ratchet wheel a few clicks.
  • Thanks 2
  • 2 years later...
Oh dear. I didn't think this element was so tricky. Good that I have this heads-up and before re-assembling.. thanks!
Alright. So HP1300 for the bushing-side, I guess. I'm a bit surprised (would have used 9010), but ok.
Thanks for sharing!
Well, well, well, I thought I had finished my service of the 551...but the seconds hand ruined my day. It's stopping, ticking, jumping all over the place. I definitely bent the pinion spring 😖
I found this video -- indicating the correct angle of the spring. Maybe helpful for others.
I'll try to get the correct bend at some point this weekend and will report back. Wish me luck please.
Thanks for sharing!
Where did you see to use HP1300? I've only ever used 9010 on centre seconds.
My bad.
I was sure I had read that recommendation in this thread, but I don't see you now as I look back. I was actually assembling the seconds pinion on my 552 yesterday night and also used 9010. Makes more sense.
Pheeew, I managed to bend it into shape with two tweezers. Nerve-wracking...
But it worked out and now it's sweeping nicely without any effect on amplitude.
I'm very happy.
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
