Remove old screw down crown seal
familyguy
I have a dive watch I purchased new, in the early 1970's with ETA auto wind movement, It's looking a bit sad and I would like to get serviced and looking nice again, it is I hope a good candidate as it was only ever serviced by a watchmaker, recently I tried to unscrew the crown, it was very stiff, when it came undone I noticed a black goo around the crown tube, looks as if the seal/o-ring has disintegrated, my question is how to get the goo out of the crown thread, is there a solvent I can soak it in. I did once have a winchester of benzene but was forced to get rid of it on pain of divorce - I'm sure benzene would have done it.
Edited by familyguy
Correct a typo
  • familyguy changed the title to Remove old screw down crown seal
Hi Ditto  old Hippy, having got a new crown then experiment removing the old goo the experience will come in handy for the future,   IPA, Ronsonol, benzine will probably do the trick, finding the correct cleaner will be handy as case back gaskets also get in this state.
Here are pics of the offending parts, movement is an ETA 2783, this is the first time I have removed the stem/crown and I notice that the square section of the stem has a twist in it - is this normal ? I'm assuming it is, as the watch was only ever serviced by a watchmaker and I doubt the stem could transmit enough force to twist the square section, I feel the the stem would break at the thread - the thinnest part.
I think you may have had benzine (motor petrol, gasoline) not benzene, the confusion is common among English speakers. Anyway the cleaning agent is not important because to replace the gasket in the crown you have to lift the top washer anyway, as said that's a bit of fiddly work but certainly doable. Or fit a new crown.
11 hours ago, familyguy said:
I notice that the square section of the stem has a twist in it - is this normal?
Yes it is, for period of time ETA was making movements with a twisted stem, probably with the idea these would help the clutch wheel pressing, then fortunately they stopped.
11 hours ago, rodabod said:
I reckon you may be able to get a matching replacement from cousins if you are based in Europe.
Even if you're not, Cousins UK ships worldwide for the actual Royal Mail cost.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
    • New one on me too.  Is that corrosion on the crown wheel?  Let us know how you get on.
    • Case in point, I just scored a lot of 4 Timex mechanical watches for $15.50 which puts the individual watches at $3.88 each, or £3.09 (or €3.59, ¥28.08 (CH), ¥607 (JP), ₹324 ... or 0.00006 Bitcoin ) 😉
