I'm confused because on the video the click us here. -
By sub2001zero · Posted
hi thank you for your help i been super busy! -
By Terrinecold · Posted
I think I found the click in the blue circle I figured this was a Miyota 8215 clone and I found a disassembly video for that -
Dont pull the bridge, that will go very wrong. Worse case is to lock the train and remove the pallet fork then with two sticks let the train unwind slowly catching the spokes. -
By rossjackson01 · Posted
Thank you Richard. Not sure why it does not run. Maybe old oil? It has never been opened before. I am the first. The balance moved OK. The pallet fork moved side to side OK. However, although the watch accepted a wind, the train did not move. All of the pivots and wheels appear correct. No damage. I have noted that the jewels and picots are completely dry. There appears to have been no lubrication at all. No wear on any jewel or hole. Maybe it stopped because of that. I hope so. Possible the owner di not do anything when it first stopped. As I said, virgin interior. I am using brass tweezer to make sure there is no scratches, and am being extra careful with screw removal. No scratches or deformity as of yet. Want to keep it that way on assembly. Already pegged. Tomorrow I will do a full clean and be ready to begin the reassembly. So looking forward to this.
