opattapp12
opattapp12
Hi everyone,
I’m quite new to all of this, so sorry if these are very newbie questions!
I’ve just inherited an old striking french clock from my grandparents, and got it running again. However there are 2 issues:
1. It didn’t have a pendulum when I got it, and it’s currently running about twice as fast as it should. Is this expected with no pendulum in place? And is it as easy as buying a replacement?
2. The fly pinion/spinner (not quite sure what the proper name is) had broken and fallen out. When a strike of more than about 3 comes around, the strikes are very rapid and often miss several strikes. Is this linked to the fly spinner not being in place? Again, is this as simple as finding a replacement?
Thanks in advance!
Oli
Hi  The answer to both questions is yes,  without the pendulum there is very little control of the escapement and it will run rapid untill the mainspring runs down.  The Strike fly is in fact an air  brake which governs the speed of the strike train so the the strike count is even and controlled.
Depending on the make both parts are able to be found through Ebay and other sites,
Have a look at the back plate of the clock and post a picture of it and close ups of any makers marks/medallions            .A.D.Mougin and Japy Feres were common makers.
I have some bits and pieces of french clocks so may be able to help.     cheers
French movements are the most custom of the movements mass produced.  Do you have the fly and its arbor?  Best to have it sent to the machinist to have it repivoted.  If not then youll have to ask sellers on ebay to give you inside dimension distance of plate to plate to find a movement with the correct inside depth to cannibalize the fly and its arbor.  The fly has an eccentric bushing such that the meshing of the fly pinion and the 4th? wheel gear can be adjusted for mesh.
Also the pendulum is an easier fix however the outside diameter of the pendulum rod should be ever so slightly smaller than the inside dimentions of the crutch fork.  The weight of the pendulum bob also affects the rate.  So if you buy a new french style rod from the supply house, start long and work your way up cutting length until you find the sweet spot.
Its work.  Nothing is easy in clock and watch repair.  But when you earn the skills you will be rewarded
The steel used in these clocks can be extremely brittle; I doubt these days you will find anyone who can re-pivot the fly wheel. The pendulum should have the same numbers on it as the back plate, if it does that will tell you the pendulum is the original, those numbers are in a French measurement for the length of the pendulum.
I known one, but probably not for a long time. If one coming from wristwatches learns that fine art, will he/she become a clockmaker? A part of myself says that is the same as a watchmaker, another part says it is not.
Edited by jdm
Drilling hardened steel and also small diameters is always an issue. If you do the math for proper surface speed at say 0.50mm you get figures ranging from 5k to 50k or more (especially dropping diameter down to say 0.25mm). Levin, as in the author and lathe manufacturer, put out a pamphlet way back in the 60s I think that broke that apart. Essentially they illustrated that at high rpm unless you can accurately feed a drill so it's taking x-amount of material off per revolution, you will likely fail. Also that materials respond differently at small diameters.
I have a cnc machine with a 10k spindle, and can tell it how much to take per tooth per rev, works great.
When hand feeding, lower rpm is really better. I generally don't go above 1.5k or 2k. If the tool isn't making a chip, it's rubbing, and rubbing work hardens most materials, which makes it harder to get through that skin, then with the added force boom it either implodes from a combination of worn tool (from rubbing) and impenetrable workpiece, or the tool manages to get through then takes a monster chip and breaks.
With tungsten carbide, even the glass hard French clock arbors can be drilled*. But it has to cut. In school we had hand cranked lathes, easy to make say 20 revs, pull the drill and check for/ clear chips, keep going to depth. Much preferable to make a hole in 10 minutes instead of 2, but not have to deal with a broken drill in the hole!
*back in the day the crazy guys would quench drills in mercury to get them hard enough to drill those arbors. Works for steel gravers too. Yes I tried.... (outside).
On a not-very-expensive French clock and specifically for the fly, I would probably try bringing the temper down where I was going to drill. You’ll still have a nice hard, new pivot fitted after.
I’m by no means a drilling expert, but my experience has shown me that you need to gauge the rpm and pressure according to hoe the work responds, and gauge how likely the drill bit is to break depending on its type. Although I use them, I hate carbide drill bits when they break and get lodged in place. Where possible, I use HSS-CO bits.
He is an excellent machinist in the North East USA.   He advertises in the NAWCC mart paper.  Actually theres a couple machinists in the mart paper ive used to repivot such small arbors.
I can repivot certain things but when it come to the micro pivoting i send them off.  As with gear cutting.  Im not setup with a mill and id rather have a machinist with the experience do that.
    • The epilame under the oil will also be removed
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
