Help determining part name?
Hello, I am working on an AS 1320 (Bulova 10BRC, 9AS) automatic movement and have found it to be missing a part for which I cannot find a name. I have looked at the 10 BRC automatic assembly parts list and the parts list for the movement itself and still cannot locate it. Here is a photo with the missing part outlined in red.
It is a spring-like device that prevents the automatic assembly's third winding wheel from engaging the ratchet wheel when the mainspring is fully wound. If anyone could tell me the name of this part so I could order a few replacement parts, I'd really appreciate it!
25 minutes ago, oldhippy said:
Can you post the link to the parts list or up load the list please.
I rember the part name list.    haveing a hard time finding it !    i'll keep looking.     vin
Hello, I used the Bulova Self-Winding Watches booklet (pg 18) and the '52 Catalog of Interchangeable Parts (pg. 79) to attempt to identify as many parts as I could.
15 minutes ago, Walsey said:
I don't believe that is the part but thank you.
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
