Timex
Deggsie
I’m not really excited about Timex as a brand. I think it’s the lack of twiddly things called screws, but I’m sure there are guys out there who love them.
I hope I’m not infringing any rules here, but if anyone would like this timex please pm me. I will put your name in a pot and get one of my daughter’s to draw it next Sunday at 5pm. If you are in the Uk, no postage. If you’re overseas I’ll let you know how much postage will be. Just to be clear, I’m giving this watch away. I’ve got a lot of help and knowledge from here and would like to start giving something back every now and again.
Let me know if I’m infringing the rules and I’ll ask for it to be taken down
Keep safe all
King regards
Deggsie
And the NAME out of the hat is ........... (imagine drum roll........ continuing on to enhance the suspense)......
ANDY HULL
Please pm me with your address and I’ll post it on to you mate.
Kind regards
Deggsie
On 5/17/2020 at 2:11 PM, Deggsie said:
Anyone think this little guy is worth reviving.
The "little guy" in question arrived this morning, thanks @Deggsie so I took a quick look at lunch time.
Nothing major wrong with it so far as I can see, but it needs a click spring, and I'm currently clean out of them.
Here is the offending spring. There should be two teeth on the left hand end, but one is missing.
Here is a comparison with the older arrangement of click and the L shaped hole for the "encheapened" more modern version.
I'll have a dig through my scrap movements this evening, but this is a common failure mode for this mechanism, and I'm pretty certain  a I've robbed the click spring from all of the scrap movements already.
@JerseyMo I may need to purchase a couple more of these to get this going and have one for stock.
Meantime, here for your entertainment are a few more random teardown pictures.
Note today's dial protector is sponsored by KitKat.
This watch is a front loader from 1979 and interestingly this one is made not in Dundee as a lot of the 1970s watches are but rather, this is one of the early Taiwan versions.
One thing they do seem to have improved on this version is the dial tabs, which are fairly substantial compared with quite a few I have seen.
2 hours ago, JerseyMo said:
unfortunately, I'm out of them too!
No worries. I have a few other options.
This for example, is coming in the mail. I may sacrifice its click for the greater good. :D
I also may try fabri-cobling together something from click spring wire, as I have a small pile of that which is not currently doing anything useful. A little creative wire bending may be all that is required. It is only a Timex after all, not a Rolex, so a little creativity is permitted I feel.
@JerseyMo You are of course quite correct, so since it wasn't a suitable donor, I did the decent thing and cleaned and serviced it.
It 'aint no great looker, age hasn't been kind to it (made in 1971),  but at least now it is no longer a biohazard, it keeps time,  and small children don't run away and hide behind the sofa when it enters the room.
The finished article.
All of the grime removed (with the exception of the etched in thumb print on the dial) crystal polished, you can now see through it once more, a quick rub down to remove the polish and hey presto. Perfect... well as perfect as it is ever likely to get.
If patina is your thing, then this should hit the spot. Optional thumbprint (not mine) on the bottom left.
I recall they came with a leather strap. You know the expression timing is everything?  well just a month ago I had a replacement dial for that watch.  Gave it away and now I can't even remember to who.  Guess my memory is getting just as patina-ed as that dial :)
I know the feeling... Now where did I put my glasses... One sec while I put on my glasses to go looking form my glass.... err... hang on a second, what was I doing?
    • As far as I know, the only time an epilame treatment has potential drawbacks is when something is rubbing on the treated part w/o lubrication in between creating abrasive dust. That is, I don't believe in the method of "running the watch to make a groove through it first in the pallet stones where the lubrication is then placed". So, I think the rule would be; do not epilame treat parts where rubbing is going on without lubrication. Other than that I don't think we have anything to worry about. That said, I'm not an expert, and I'm always happy to learn more. Has any other repairer than Alex suggested or explained the "making-a-groove" method? My impression is that it's just something he constructed in his mind. I have not perceived it as a generally practiced method. Again, I could be wrong!
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
