checking in
Thank you for your introduction and welcome to this friendly forum.
I think that is the briefest introduction I have seen on this forum.:D It would be nice to tell us a little about yourself. What is your interest in watches/clocks.
Haha. Okay, I'm a late 40s dude with a military background and also a financial planners work history. I've been in financial services for 15 years and wanted to make a change given the circumstances in the world. I've been a mechanic since I was a pup and the last time enlisted in the army, I worked on Apache helicopters (D models). It's been a hell of a road over my life. I really wanted to immerse myself in a craft that is as precision as aircraft maintenance without the physical requirements, since I had some major surgery caused by my last enlistment. What I really want to accomplish one day is to create a watch from scratch and to make it a custom piece; I saw a watch that was made entirely from wood (except the mainspring and hairspring) and I just fell in love. I feel I have enough creativity and ingenuity to pull it off and most importantly, I love this kind of work! I look forward to my career in watchmaking.
    • Surely it depends on the clock , I only usually restore torsion clocks and I only use oil on mainspring ( small amount) but on the few so called normal pendulum clocks I have done I have used mainspring grease as there is more reserves of power than there is in a torsion clock so it is not so critical. Dell
    • https://watchguy.co.uk/cgi-bin/files?showfile=Venus/Venus 178.pdf&filename=Venus 178.pdf&dir=Technical Manuals&action=documents   The hour recorder is driven by the barrel and it will only stop if it is held by the hour recorder stop lever 8690. So I would check if this lever (powered by the spring 8691) is really holding the hour recorder in the "chrono off status". I haven't worked on a Venus 178 so far, but on an Omega 861 I chose 9501 grease for the friction spring as it's moving very slow at quite high tension.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
