Seiko 5 7S26B... sigh
My latest project is a Seiko 5 with a 7S26B. First, I could tell this was going to be a real fixer upper when the pallet fork stuck to the bridge from too much oil. I now have to find out what size screwdriver to use on the one sole phillips/cross screw under the calendar wheel. However, after looking closer at it, it is stripped.
So, I need to know what size screwdriver to get for this one solitary screw and what to do with a stripped screw.
Thank you for you help on advance.
4 screws (3x A type and 1x B type). First we will unscrew one B type screw, part number 0016 705. It is a phillips head screw. (Another unorthodox component!). To be able to remove this screw, we would have to make a tool - a "half phillips head screwdriver". :-)
Seiko 7s26 diy disassembly - date indicator maintaining plate
Place a sheet of medium coarse (400 or 600 grade) sand paper on to a flat surface and shape the blade of your smallest size screwdriver (40 or 60 / 0.40 or 0.60mm) as per photo.
Seiko DIY 7S26 - 40 or 60 screwdriver
DIY Seiko 7S26 - 0.40mm or 0.60mm screwdriver
Seiko 7S26 Date Plate screw A
Seiko Date Plate screw A
Hi there hope this helps. Hopefully you will get enough traction to remove the screw.....:)
Edited by Graziano
4 hours ago, sjhilbel said:
Graziano, this is great! I’ve been search for this special screwdriver all day, when I could have been making my own. I’m still a watch repair noob so I’m still learning these tricks. Thank you!
All good take care
That's a nifty trick @Graziano and the illustrations are just brilliant! Thank you! Anyway, Cousinsuk.com have this SEIKO S-921 screwdriver in case you don't want to make your own tool.
Did you make your illustrations to answer this question in particular or are your pictures from a walkthrough? In the latter case could you provide a link?
This is great info enjoy https://www.clockmaker.com.au/diy_seiko_7s26/
1 hour ago, Graziano said:
With all the due respect, I do not agree that the above is that great, or even that should be given as an example all the time.
For one, is incomplete, ending with train is placed together. And some practices are debatable, for example the one of opening the barrel and fitting the mainspring without a winder.
I recommend the OP to look instead at the video below by hour Host Mark Lovick. He also made some more about the same mov't. Even better would be to enroll in his training,
watchrepairlessons.com
Edited by jdm
52 minutes ago, jdm said:
With all the due respect, I do not agree that the above is that great, or even that should be given as an example. For one, is incomplete, ending even with the train is placed together. The, some practices are debatable, for example the one of opening the barrel and fitting the mainspring without a winder. I recommend the OP to look instead at the video below by hour Host Mark Lovick. He also made some more abput the sam mov't. Even better would be to enroll in training, watchrepairlessons.com
The original post was about the screw driver required for 0016 705 screw ,this method of filing down works for burred screws as you can work the screwdriver to fit the stripped head enough to get traction in most cases works for me ,enjoy I don't see your problem :jig:
Edited by Graziano
Reading the following on the SEIKO DIY site Graziano linked to was a bit of a turn off:
"If you are just an amateur horologist or hobbyist, then it is highly unethical, unprofessional and most likely illegal to repair other people's watches - even if they want you to do so."
Being exactly that, "just a hobbyist", it feels like a pretty condescending statement, especially as it's given without any kind of explanation.
Anyway, I really enjoyed how thoroughly he goes through what the various SEIKO numbers mean, and I'm sure I'll have more to learn from that site, so much appreciated Graziano. I'll consider it a complement to @Mark's excellent 7s26 videos on his YT channel.
I think you misunderstood the scope of my comment. I have no quibble about that detail, but expressed my general opinion about the 7S26 articles by Mr. Hacko.
Again to help the OP, without even leaving this forum there is plenty of detailed photographic information on  the very popular mov't.
47 minutes ago, aac58 said:
I use a 1,2 mm phillips screwdriver from a very cheap chinese set and it works just fine for that screw. A 1.0 mm will likely work too.
The original post was about a stripped screw ,the method shown above allows you to work the screwdriver with the sandpaper so that you ca get traction on a stripped screw ,Maybe I should of made myself clearer
I agree with you Mr jdm I was just showing the op a way of shaping the screwdriver to undo a stripped date plate screw that will allow traction enough to undo the screw ,most of the time it works .Thanks
Hi VWatchie , thank you for your comments but don't take it to heart I'm sure that some of the remarks that are written there are only there to protect their own investment and for legal reasons .I agree with you Mr VWatchie that Marks videos are far more informative and he has respect for the hobbiest . Thanks
Thank you to everyone. @Graziano provided a great way to remove the stripped screw. I appreciate @VWatchie link to the specific Seiko driver. I am also grateful for the attention to detail and professional guidance everyone provides. As a beginner, I want to do repairs well and properly. I am following @Mark’s 7S26 closely for this repair. I’ve found myself searching for the same watches he repairs and records in order to learn.
Again, thank you, everyone.
That's awesome :thumbsu:
I just realized I never gave an update on this.
I tried a number of other methods. The only method that worked was getting a watch screw extractor on eBay. It was cheap and did the trick! I was able to remove it and proceed with the movement disassembly. However, when reassembling I noticed the Day-date corrector meeting wheel spokes didn't look symmetrical. I picked it up and a tooth breaks off! :angry:
So now I'm in search for Seiko 5 7S26B parts. Outside of eBay, the sources are very scarce due to COVID-19.
To add insult to injury, my next project watch (a Volstok) is stuck in NY either in customs or USPS.
May all of you projects be going well and stay safe!
The 737.183 corrector is available from Cousins UK although relatively expensive, and is the same across all version of 7S, 4R, and their SII counterparts.. Ebay is alway the best source of donor watches or mov't which will give you more parts for future repairs.
I don't get it. I ordered an Alpha watch from Lithuania -- a Panerai homage that uses the Seagull ST1901 chronograph movement that Mark is using in his upcoming complications lessons -- and it took almost 10 days to get through the NY/NJ USPS customs. And that was before COVID-19 was a thing. And, in transit the thing must have been dropped because it was damaged on arrival. Tomas from Alpha was kind enough to replace it and it took only 6 days to get from Pennsylvania to Lithuania on the return trip.
I GOT MY WATCH! Yesterday, the tracking said it was still in NY. I checked the tracking today and suddenly it was in my town, out for delivery!
The watch is a Vostok Komandirskie with a 2414A. Now off to find the illusive Votstok watch repair guides!
I did check for the Seiko corrector wheel on Cousins. For just that wheel and shipping, it would cost $10. I might as well by another repairable Seiko for $30 and have that many more parts! :biggrin:
Congrats! :thumbsu:
You might find my Vostok 2409 Picture Service Walkthrough useful. The only difference between the 2409 and the 2414 calibres is the very uncomplicated calendar complication which I've documented in this post. Good luck!
EDIT: You might enjoy this guide.
Edited by VWatchie
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 at 20° C) than 9504 (305 at 20°).
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
