Rookie mistake
JJM
Is it possible that I could of unintentionally shifted the position of the setting lever jumper & connected items removing the handsetting stem roughly?..... The stem is refusing to go back in.... I'm a 1st timer, so this is all a bit new to me.. Just trying to get things clear in my mind before I proceed.
It's a Ronda 4220b movement (Well it was when I started) With a none functioning date change fault.
I have the Tech Instructions, which is handy.
Hi Its entirely possible, Some movements require the stem in the set position when removing the the stem, If not the crown and castle wheels displace and until they are realigned you have no chance,   Remove the dial and hands and inspect the keyless work for shifted parts.
From the dial side, you may be able to figure out what went wrong. Chances are, as watchweasol said, the crown/clutch parts are out of alignment. Take care if you remove those three screws holding down the top plate, things can escape from their confinement beneath, and vanish into the ether really easily. As this is a quartz movement, those "things" are likely to be particularly tiny, and difficult, if not impossible to locate, and just as difficult, if not impossible to source as spares.
Edited by AndyHull
8 hours ago, yankeedog said:
Have you looked into the price of a new movement?
I think that unlike other cases where owners come here asking about quartz modules, here the OP's intent is to learn, not just fix something. Starting with a quartz is perfectly fine, I wish him success.
Edited by jdm
I am trying to learn some new stuff here. I know I can get a replacement unit, however my plan was to at least try to fix this one. Right now the project is on hold as I need some better magnification.... These bits are astoundingly small!
Thank You for your input folks.
Edited by JJM
     i think,  once you take the dial off;       you will see how the mistake was made.    good luck.  vin
18 hours ago, watchweasol said:
Hi  Did you get the full tech sheet about 6 pages If no I have it If you need it      Cheers
Yeah, I grabbed a copy from the Ronda website. I need to address my lack of vision right now. I'll ebay up a 10x loupe, hoping that will be enough.
x10 is very strong, normal work should be done with 5x or even less. Get a loop also or you will dropping it all the time and getting face muscles strained.
Edited by jdm
I started off with my trusty £1 shop reading glasses that I used to use for close up fiddly stuff @ +2.50 .... They won't "Cut the mustard".....Then another pair at +3.50 nope still not enough....
However giving thngs a whirl with the +3.50 glasses, a little light disassembly from the dial side I am able to see that the round leading end of the handsetting stem is entering into the sliding pinion & then we grind to a halt when the square section of stem arrives, tried twisting & that doesn't seem to help. This is a lack of magnification thing, that & all the stems pinions & levers seem to be mounted on the other side of the 'Main Plate' so I'm thinking further dissasembly will be required. I'm not willing to proceed further until I can see properly, I have noted that jewels are located on the bridges & I don't know if they are likely to make a break for freedom. Should they do just that & I'm working blind...... Well thats not a position I want to put myself in.
On the brighter side, I have inspected as best I can the date indicators & the teeth look, well, "Mangled" in places, the units less so, but the tens look like they've been chewed by a "Rhinoceros"... Cogs being cogs I'm expecting to find further damage when I locate whatever contraption drives this assembly.... I've had a look round for the availability of spare parts & things are looking good, expensive, but good ....... I did loose the battery retaining screw while disassembling however oem replacements are available. I intend to wait until I have the full picture as far as parts go ........ We may well end up in uneconomic to repair fully territory. If this proves to be the case rather than create my very own "Triggers Broom" I'll replace the whole unit & recommission the watch, then work on this unit & mount it into a another watchcase with a dial that doesn't have a date window (Well its good to have a plan)
Some of you may of seen my other post on my alternative methodology dealing with a damaged Crystal..... That too is a "In Progress" item.
Edited by JJM
Spelling mistake :(
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
