Bet I'm not the first
JJM
I can happily announce the crystal is out! :unsure:
I shouldn't think I'll be the last to adopt this unorthodox approach, the crystal was damaged prior to this violation of horological etiquette. Yes I did cut myself & no, on reflection, I concede it wasn't a very good idea. :Bravo:IMG_20200309_154136.thumb.jpg.b2f01b9d34f3d9c1090b095f61a4f2d3.jpg
  • Confused 1
-_-
6 hours ago, AndyHull said:
what kind of a barbarian are you sir?! :wacko:
Fair point! ...... Well I saw on a Ulysse Nardin video a operative enamelling dials with what appeared to be a pizza oven.... So I just thought...... Its Horological/Liberty Hall here.
I'm wondering if I use a smaller hammer I could fit the replacement crystal utilising a similar methodology .....  I guess its more a gradually increase of pressure as against a short sharp shock..... Using weights perhaps...... Or my foot?
This all started by me needing a battery replaced & now look!
  • Haha 2
Have you tried a hydraulic press ?:chainsaw:
Image result for hydraulic press pictures
Edited by Graziano
Oddly enough I did have half a thought of rigging something up using a bottle jack.... I really should get a purpose made unit, maybe drop £10 on Ali express & see what happens... Cash is slim this month though
On 3/10/2020 at 10:49 AM, watchweasol said:
Hi  Iv'e got it the toaster is to warm the bezel (expand) and with medium pressure from the hammer and socket, a perfect fit:D
No bezel on this one..... Mind you, I could retrofit one utilising heat & some strategic percucussive techniques...Great idea....! I'll whip the 'Pot' bezel off my Daytona of Eastern origin & mock it up for sizing :P
Well we seem to have progress!
I will take this as a win
Its in the same position as the original
There it is, looking awful covered in finger prints .... But its in, in level & not broken
As I didn't replace the crystal gasket I think it would be unfair to expect it to be watertight.
The technical details: Original glass Ø35.87mm the replacement Ø36.46mm. I'm not too sure how
accurate these chinese digital verniers are, (£7.00 worth ;))  As at the time of ordering
I didn't have any suitable measuring devices, I did the sensible thing & looked online, took a
strangers word for it, what could go wrong ? ...... The maths says the replacement crystal is .59mm oversize
but I am living proof that "You can make anything fit if you have a big enough hammer" .....
Conclusion: I think I've been mighty fortunate, however I have also demonstrated that with a kiss from lady
luck & a modicom of digital dexterity this watch fanangling is a breeze. :Bravo:
Edited by JJM
Spelling as usual
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!?
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
