are these interesting?
Ammar
Hello, I have been looking for a new project for a while and I wanted something new and interesting  so I found these two watches but I couldn't find any information online on them because the guy who is selling them just sells used stuff and has no idea about watches so I want to no if they're worth my time.
2 minutes ago, AlexeiJ1 said:
The Seiko is a horrible re-dialed hodge podge. I wouldn't touch that.
The Tag is even worse fake.
thank you very much I probably wouldn't have known if I got them because I'm new to this hobby.
may I ask you about this one then, do you think it would be a good project.
(I know the crown is missing but I have a lot of crowns laying around so it's not a big problem)
Hi   The other two if you can get the pair for £15  worth it for playing about with. on the seiko's look on the case backfor a series of numbers then look at the dial under the 6 oclock position  there should be some numbers  eg  7009     084 or the like  these should match some of the numbers on the back  if not they have been cobbled together for sale the whole handfull   £20 to 25  no more.
Only the crown or also the stem is missing? And even if if you had the stem, would your crowns fit well?
Is not difficult to bring back old Seiko 5 to wearable conditions, just do not expect them to be "best of breed".
they're more expensive than 25£ I am not getting them.
I bought a part lot the other day (mainly Seiko) and there's a lot of stems and crowns so I'm not worried about that (although I'm the unluckiest guy in the world and it's gonna turn out that I don't have this particular crown)
I don't really care about wearing the watch I just need to practice, it's hard to find decent watches here because we don't have ebay and people just tend to throw their old watches away.
Hi  If you are looking for movements/watches to practise on then I reccomend the Russian watches Wostock  Raketa Plojot etc  they can be picked up for a few pounds each, in most cases working. If you make a mistake working on them you have not lost a lot.  Worth checking out.
I'll see if I can find any of these brands here, thank you.
Does it have to be from your country? You can buy on Ebay in Europe or even worldwide, many sellers ship internationally to the actual cost.
Second  on Russian  movements.
shipping isn't the problem with ebay, it's the paying method the government here banned PayPal a couple of years ago and turkish credit cards aren't accepted on  ebay, some sellers accept bank transfers but they're are really expensive.
also I am not a Turkish citizen so transferring money isn't that easy anyway.
I see. Maybe you will make some friends here or elsewhere to buy on your behalf.
I really hope so, it's really frustrating when you want to do something and you can't do it because of a stupid reason  that's out of your control.
thank you :thumbsu:
I definitely second that too! For example:
1 hour ago, watchweasol said:
Hi   I am surprised you didnt find any there are usually plenty on ebay to be had, try the Racketa,  Sekonda,  Just look up russian watch movements.in general
Yea we don't have ebay here :mad:
35 minutes ago, watchweasol said:
Hi  sorry did not realise you guys are limited , what have you got access to in the way of a market place.  We sort of take it for granted the fact we have free access to the web uncensored.      cheers
No eBay is not censored in Turkey, (other sites are} and even if it was VPN are normally used to circumvent, but the OP cannot use PayPal as he explained above. Other countries are also like that for sure, or impose crazy duties, etc.
Edited by jdm
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the whole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
