"Master" watchmaker
I've received a 2824-2 watch with the complain that it stops. Just looking at it in jeweler's shop I noticed:
  • date misaligned
  • date changes at the wrong time
  • caseback opening scratches
  • doesn't hack
  • weight hardly turns
Then while disassembly
  • one casing screw missing
  • both dial feet snapped flush and consequent double side tape
  • lots of oil in the oddest places, like under barrel bridge
  • missing stop lever
  • barrel bridge screws lose, likely that's why the ratchet wheel left marks on it and it would not auto wind.
  • driver scratches on the barrel
One could think that was the result of an improvised repairer or owner. Not so, as it happens it was given to this small town shop which proudly has a sign outside: "master watchmaker". After a long time and much money the desperate owner wanted to try someone else to repair it. I hope to be able to.
  • Confused 1
Some more evidence. May be the idea is that you mark parts that go more or less together?
I have reassembled the mov't and timing is flawless. But i'm afraid the issue with auto winding is still there, I may post about that separately.
Jeezumpetes.
I just got a Baume & Mercier chrono, was serviced 6 months ago by B&M, 800 bucks. Stopped. Sent in for warranty, they said it was dropped, not covered. Ends up on my bench....
2892 with Dubois Depraz module. Straight away, auto module was barely screwed on. Get to taking the dial off, one dial screw missing. Found it in the chrono module, put it where it belongs, double checked all the other screws, and it runs great.
And the brands don't want to distribute parts because us indie guys are hacks.
Hahahahaha.
I always scratch and "X" into every part I touch to remind me that it cleaned it. :rolleyes:
Not just watch brands ... auto makers, tech companies, big pharma ... don't get em started.
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
