I added this lovely Timex electronic to my rotation yesterday. The blue dial surrounded by a black shadow like this is very appealing to me. Thanks again to @JohnD for inspiring me to get it.
This is VERY cool! I love this watch.
I replaced the Mercedes hands on this Invicta. They just didn't look right with that Seamaster pattern scalloped bezel.
I LOVE this blue sunburst dial .
Latest arrival, this 'Limit' Swissonic ESA9158...
This Avia Swissonic ESA9154 is in the post.....
Edited by JohnD
17 minutes ago, FLwatchguy73 said:
Timex "mystery" dial watch. Love the midnight blue:wub:
Bugger that's another one I'm going to have to look out for!:unsure:
Powder blue dial (which doesn't really show in these pictures) with light blue lettering, so it kind of qualifies as a Blue dialled Timex.
Circa 1964, and manufactured in Dundee. I must admit the mystery dial above puts this one in the shade. I don't suppose you would consider a swap? No? Thought not.
There are several versions of "Timex Cinderella", and later versions have a picture of the Disney character on the dial.
Omnia BG866 based late seventies pin lever with the ubiquitous for the time, offset crown.
I posted this recently on the Watch of Today thread. Of the three, it is far and away the winner, despite the pitting on the plating.
Edited by AndyHull
Late addition to blue dials; this is a Pulsar with Seiko 7s26 movement. Does not wind, nor does it hack, but nice looking I think.
  • Like 5
That's the mistake I made by looking back from the beginning of the WOTD thread. No joke, I bought 5 watches I fell in love with there!:P sometimes I like to be original, but when a watch is cool, it's cool, even if I'm not the only one with it.
9 hours ago, GomBoo said:
Why do I like that?.....:)
Bob
1972 Timex Marlin 21 Jewels
interesting. did you buy that from me?
No... It was a gift from my favorite local Watch Finder.
Are you saying that one is on the block?
Bob
Edited by GomBoo
vvv
Bob
The one I posted is indeed listed for sale. You can find it over on the bay.  But, did you know the one you show is not original.  the case should be gold toned.  The chromed case was used on the one I show and another with a multi color dial and white hands.  If I recall correctly the case style is a homage to an Omega that was also marketed in the early 70's just as these were.
  The movement stamped 'Britain', I've been looking for a while and I have never seen another Black dial Marlin with the gold block indices. The silver case may be an over the pond thing, I'll ck the 'bay'
Thanks
GOM
    • I am puzzled by something a snipped out something from your image and what exactly disassemble tell us? my confusion is the symbol for FHF looks like image I have below year symbol as a star and righted this instant are not finding what that means? I suppose we could use the fingerprint system to verify it really is what it claimed to be. Size itself is really interesting there's almost no watches in that particular size. Then were missing details in the photograph above like diameter of movements to verify it really is the size and are missing the setting components.   went to the bestfit book looking at the symbols didn't see it. Look at the link below I did find it back to the bestfit book and yes it really is there https://reference.grail-watch.com/documents/history-of-ebauches-sa/ then bestfit book says lists the size as 10 1/2. one of the problems with vintage watches is finding parts yes a donor watch would be good.
    • Actually, this could be the issue. Drag from the module could be overcoming the cannon pinion. It was definitely not at the point that the driving wheel was loose on the cannon pinion, it took a little bit of effort to rotate it when applying the grease. Maybe I need to look again at applying oil to the pivots.    Yeah, it's very annoying. I don't want to give up on it, so back on with it over again until I catch a break.
    • The sping is not pushing directly on the cap, but is pushing against the spindle. So, even if the usual black cap is replaced with the micrometer cap, the spindle is still pushed up.
    • But he tells that the micrometer cap doesn't screw into the spindle. How can the spring push the spindle up if there's nothing to grip? There is a screw visible on top of the micrometer cap so should it be able to screw into the spindle? I'm feeling really dumb now. Does anyone manufacture that cap as an aftermarket item? Might be worth investing. Ok so the spindle is different, now I get it.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
