I think the hour hand is loose, best to uncase the movement, remove the minute and hour hand, peen the hole in the hour hand then reinstal the hands. Dial should protected just in case a tool slips as you press the hands on.
Thank you for your help but never done this before and I am so scared to touch this and maybe make it worse.
Ibought this back in 2020 and it still is going nowhere wrapped up in a case.
Terrible
I reached out to marshall Sutcliffe on YouTube to see if he will have a look but no reply at all.
Can anybody remove the hands ?
Also did you see the picture I posted of the new stem ?
Does that look like the right one?
Shouldn't personally attempt it then.
Need to have number of dimention of its profile to tell.
13 hours ago, Gordie said:
I have no skill to know or repair what is wrong
I think we need a clarification so I quoted something no skills to repair a watch correct? Is this an easy watch to fix may be but it requires skills. It's a Omega watch and as you noted finding a nice clean perfect older Omega watch is a challenge or maybe it's impossible? Having the problems you're having makes you wonder if the watch was really serviced at all. Sellers typically on eBay exaggerate the reality of the situation and usually don't backed up or guarantee what they've sold. Because if it had been recently serviced it should have a warranty and it should go back to wherever it came from.
If you've never done watch repair learning on an Omega watch is not a good watch to learn on. You need to find somebody who knows how to work on a watch and have them fix the problem. Otherwise things are going to really expensive really fast. Because there are not a lot of Omega parts out there.
So to help us what is your watch repair skill level experience? Then can we get a picture of the inside of the watch in other words take the back off?
Hi  What JohnR725 has explained is spot on, without any prior experience the removal of the movement and re fitting of the hands without the equired skill level is frought with problems and as its an omega expensive ones and therefore best left to some one with experience.  Again pictures of the movement and any numbers are always informative.     cheers
  • 4 weeks later...
I have a very basic Seiko quartz (circa 1979) that is not working and looks a bit worn but has a lot of sentimental value.
I would like to find a very reliable person who will thoroughly clean and repair to new condition without removing the scratches.
How do I proceed?
Thanks.
Hi Depending on your location  Try The BHI British Horological Institute web sie for bona fide watch repairers or in America  the AWCCI American Watch And Clock Collectors Institute    or The NAWCC  North American Watch and Clock Collectors any on of these will have a list.
Be advised, most reputable repairers do not work on "popular quartz" watches, and even if they would, the cost is high.
  • 11 months later...
I live in Thailand and have a Corum Admirals Cup with the rattrapante complication and it needs a service. Does anyone know of a watch repairer in Thailand who could do this for me. I have other watches to wear so can be without it or a while (perhaps this complication is of interest to the esteemed Mark for use in one of his videos). The watch is a recent acquisition and I doubt if it has ever been serviced so needs some loving attention as I don't even need to put it onto a timegrapher to see its daily rate is minutes rather than seconds out. There are lots of places advertising watch repair even one in Hua Hin where I live but I am reluctant to entrust this into the hands of an unknown repairer.
    • Thanks for the info - I'll go big on the gaskets... Wonder if anyone sells hundred packs?!
    • Looked into this some more and I believe that some of the increase in rate is attributable to the drop in amplitude after 12 hours off wrist, from 300 to 275 degrees horizontal and some is due to the lower temperature (38 to 18 degrees). I can see that approx 3 to 4 seconds a day is attributable to each. I can be happy with that.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • Hi all, I'm almost ready to make my first attempt at watch repair. My initial goals are very modest, just to get an inexpensive watch or two to work on, and take it at my own pace. I have what I think are the necessary tools on the way. A couple of things arrived already: a loupe, some tweezers, and a cheap demagnetizer. After looking at the options for oils and grease, I decided to start off with Citizen A-O2 and A-O3 oil, and Seiko S-3 grease. The Moebius was just too pricey to buy this early into the undertaking, when added to the cost of the other tools I've bought. Screwdrivers are Kwong Yuen for now, but I took the frequent advice on tweezers and bought Dumostar 3C and will probably add more DuMont later. I'm looking forward to making a start. I'll need a watch to work on, so I'm trying to line up an auction purchase within the next week. I've been mostly looking at Seiko and Citizen, and will perhaps a Seiko Crown if I can land one at a decent price.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
