6119 spec sheets
Hello everyone!  I’m trying to figure out if parts from a 6119 will be compatible with a 6138 and to that end I’m looking for a spec sheet for the 6119. I’ve already received the 6138 sheets courtesy of you fine folks here, wondering if the other is available.
Also, is there a specific area of the forum I should be looking in for the specs?  I haven’t seen one in my ramblings.
20 minutes ago, watchweasol said:
Hi   I think this is a better sheet than the SCWF one its clearer.
One nice feature of this forum software is that we can re-use attachments we had included before, saving us more uploads. From the "insert other media" chose "existing attachment". Type in few letters that identify it, and you will be presented with the relevant matches. Select one or more, then the green insert button.
Edited by jdm
11 minutes ago, watchweasol said:
Thats fair enough jdm   I shall refrain from posting anything in future.  I looked at the SCWF sheet and it wan't well copied so I attached the other sheet.
Maybe you got my intentions wrong. I merely indicated how one can do faster sharing one's own existing attachments. Could be useful to you as a frequent provider of this type of information, which is always appreciated.
Edited by jdm
Hi   I do it this way because all the files are located on the computer as PDFs having been gathered over many years and stored . I also have access to a collection on printed material and a lot of books collected over a long time. I have been repairing clocks and watches for almost 60 years as a hobby. I joined this forum ( the friendly forum) to help others when required, Look for no street cred or anything else just to help those not so clued up whenever I can ,.
Please keep on the good work W W.  Your posts have been helpful.
2 minutes ago, LonglineOjoe said:
Thanks for a all the help once again!!  I feel as if my posts are always stirring a hornets nest though. I hope it’s just friendly banter :(
No wasps and no banter, I have just been misunderstood while suggesting shortcuts to posting helps. Good luck with your repair!
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
