Mainspring Barrel Arbor
spiro13
Could be hard if the mainspring is new and the arbor is larger then the loop . Try to lean it in from an angle . With the tab  to the opening . You could use a pin vice to hold the arbor . Ones in it will correct itself when you first wind the movement .
Yes to both above. Ideally you have a mainspring arbor holder (yes this is an actual tool and darn handy), basically a slide locking pinvise for distinct diameters. With this you can confidently coax the most stubborn arbors into the mainspring loop. I have a bunch of them but honestly most of the time I use sturdy nickel tweezers and the tilt-it-in technique. I also have a number of hours of barrel arbor floor searching under my belt.
I lay a thin sheet of rodico and make a divot for the end of the arbor. This holds the barrel securely.
Then proceed to hold the arbor flat while working the spring around with a needle (oilers are too delicate).
Anilv
    • Drat and double drat i was looking forward to the royalties on that idea.
    • Compression Spring Various Size. This might be helpful. I have watch furniture restorers and how they go about this problem, they inject glue underneath with a syringe and clamp it, leave over night. Next day remove clamp and it smooth. You could use an iron but be careful not to burn the wood.  https://www.ebay.co.uk/itm/265697329513?chn=ps&_ul=GB&var=565484998457&_trkparms=ispr%3D1&amdata=enc%3A1jd_-94ilTHWZLQ3PxHeC1A73&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=565484998457_265697329513&targetid=1647205088320&device=c&mktype=pla&googleloc=1006662&poi=&campaignid=17206177401&mkgroupid=136851690655&rlsatarget=pla-1647205088320&abcId=9300866&merchantid=119334104&gad_source=1&gclid=Cj0KCQjwir2xBhC_ARIsAMTXk849TnBArEYdgv1DpHf_somCZYmB7ViqD3UtvNJJc_dn4kj0AFxBXngaArSAEALw_wcB
    • 🤣 i think your first statement is rather dramatic, but i will take it in good humour.  I think the thread speaks for itself John.  What we are aiming for and when i say we, thats not actually that many that have spoke up. Is to have a back up plan to keep members in touch in case the forum ever disappears. So in essence yes the group has maybe taken on a life of its own and would like to remain together forever ( 🤣 i can also be dramatic )  maybe more members need to give some input of how they feel about it or say they are just not that bothered.  Either way at least the question gets answered. Can i ask what the forum means to you and how you would feel without it ? Thats one answer Rich from one person, without knowing how others feel the thread was just a waste of time. Aw Rich are you saying you'd miss me ? I'm touched 🙂
