I had time to kill before an appointment today so I popped into a local thrift store and asked if they had any watches, The lady rummaged under the counter and brought out a box of random quartzs and, under a bunch of Genevas and "Frozen" watches, I saw this:
Made in 1911, grade 336, 18s, 17 jewels... I said, "Yes, I think I'll have this one, please".
It will run nicely sitting on its crystal but the balance wheel catches on the underside of the balance cock when turned on its back. There seems to be a substantial bend in the hairspring that may be the cause.
I think I'll hold on to this one for a while.
Hairspring looks good to me, much more likely broken balance pivot or jewel or pivots or jewels, don't mess up the hairspring!
Could just be solidified oil and everything is fine. Just don't muck up the hs!
Unscrew the hairspring stud screw while the balance is still installed (will make things easier) and remove the balance afterwards. Don't unscrew it too much so that it falls out of the slot.
Then you just remove the hairspring and balance like any watch, yes.
28 minutes ago, MyFavoriteObsession said:
I've only had minimal experience taking balance assemblies in and out of wristwatches so I'm not sure I'm capable of this repair. Is removing the balance cock to check the pivot on this Elgin more or less similar to the procedure on a wristwatch?
     have you looked at a video or read up on removing the balance.      vin
     the hair spring can be reshaped with "rounding plyers".   i'll post a photo.    vin
I removed the balance as you described and the pivots looked really good on both ends. The jewels also looked good. Put back together and it still did the same thing. Then I noticed the hairspring is touching the underside of the balance bridge when the watch is turned onto it's back, preventing it from swinging freely. Oh well, there's time to think on it.
When the hairspring and balance are in place can you try to figure out why it is touching the underside ? Best to do that before taking any measures such as modifying components.
Is the hairspring itself horizontal as it should be ? Are there coils that are not synchronized with the rest of the hairspring ? What about the hairspring leaving the stud, is there any issue there ?
Update: I reshaped the hairspring just a bit and it's no longer touching the underside, however it still stops working when turned over so you and Nickelsilver probably right about it being a pivot or jewel. When I turn the watch over, I hear "tick tick tick tick scratch scratch clink" and it has stopped. Do you think that indicates a broken balance pivot?
I can actually make a new balance staff on a lathe.
Remove the balance complete as you would regular ones.
1- Unscrew the stud screw.
2-Remove the cock screw, lift the cock balance assembly( balance not dangling)
3- Turn the boot, check that HS is free to get out of regulator slot.
4- Grab the cock with tweezers balance dangling, hold about a cm or less above bench, push the stud out. Let the balance drop on bench or parts tray.
Diagnostics starts with a close up of pivots. Damaged or worn short pivots are expected.
Pivot shoulder rubs on jewel if pivot is short.
    • Of course, donor movement is needed, but the balance/hairspring assembly itself can be saved. OP, You just have to use tweezers and needle to straighten and two tweezers to untwist if needed to rectify the outer coil. What is seen in the middle may be is because the stud pressed to the spring, but we will need pictures after outer coil rectifying. The regulator and stud carrier are snapp-fitted on the antishock assembly. Lift and pry them together with some sharp tool and they will come off.
    • A good learning piece but think for the price of a new movement that's all it is. Probably just transfer the rotor if it's Citizen branded.
    • I'm no expert, but I'd guess this one is for the bin. Looks like it's been tinkered with by someone armed with a hammer and chisel. When the pallet, escape wheel and balance are all damaged it's beyond repair isn't it? Or a new movement if the watch itself is of value.
    • No need for special tools. Loosen stud screw and just push hairpsring stud out of the hole.  Regulator arm is spring circled around the setting housing, insert cutting edge of a safety blade under it,  opposit ( 180 degrees) to regu arm itself, and pry  half of the circle up, you then see how it all is made at put together. Remove the mobile stud carrier as well,  reinstal in proper order, first goes on the stud carrier, second put the regulator arm on top and press it home. Exactly as nev explained above. Trueing inner coils is done when balance complete is seperated from the cock.   The part thats bent over itself. 1-Unbend hairspring as much as you can when balance is seperated, just grab the hairspring stud in tweezers , grab hairpsring with another tweezers streighten with  strokes as you  move the second tweezers  away from the stud. 2-Move stud carrier and regulator arm as wide/ apart as they go , to provide max space which comes useful in next step. 3- Fit hairspring stud, into stud carrier hole. 4- Put balance and cock ( when attached together) back on mainplate.  5- You have enough space to grab hairspring in  tweezers to shape as you move your tweezers  away from stud.
    • Probably more than you need to know in these two vids, but sharing because I found them quite interesting. 🙂
