pallet jewel replacement
gary17
Hi
Is replacing a jewel in a pallet fork to much for a novice with no pallet setting tool or any pallet jewel setting tools.
Also no shellac.
I am just asking as its a cheap lanco i am messing with and one of the jewels is broken. I can buy one from cousin for £5.00.
Should there also be a small locating pin on pallet shaft for it to locate in the jewel on the movement?.
NOT recommended but, You can cheat by using a super glue or epoxy since this is just a cheap movement for practice so there is no concern on having issues with future repairs. I would say use sone sort of slow drying or repositioning epoxy. I say this because one of the reasons why shellac has been used for 200 years is because it can be heated and cooled allowing for adjustments, esp on pallet stones where position is extremely important for getting the correct lock/draw on the escape. So you will need to use a glue that wont set right away. As far as your last question I don’t understand it. When you say locating pin do you mean “pivot”? Or are you talking about the safety pin located in between the fork, if so it looks to be there. If its a pivot which goes into the pivot jewel on the movement and bridge then i cant say for sure with the pictures provided.
Edited by saswatch88
I  position the pallets, instal to observe the fork do its jumps.
Fork shouldn't hit the banks hard and escape wheel do the famous drop just before the fork reaches midpoint of the banks.
Remove the fork for any  pallet repositioning.
Glue like saswatch said.
Use proper oil, hope for good amplitude.
Regards
Edited by Nucejoe
Observe escape wheel to see pallet do the drop.
For someone who is not experienced this sort of repair could be a nightmare. Never ever use superglue, use the proper shellac which allows adjustment, super glue will not and you could end up breaking the pallet jewel or bending the pallets.  You need the correct size pallet stone, you have to have the correct position of the jewel for the whole escapement to work.
Setting pallet stones is not an easy task even with shellac, heating it to the correct softness and setting jewels will be enough to make you quit the hobby, having a pallet warmer will def help a lot in this endeavor, using a small extra piece of shellac on the pallet warmer or bluing plate separate from the pallet will be used as a guide to know when the shellac used on the jewel has the correct consistency.
 I agree with clock boy about not using glue. But for the sake of learning i think its okay, esp if you dont want to invest in the proper tools and the movement is not valuable. I cant say the results will be satisfactory since I have never tried it. Just know that even if by some miracle you are successful i will not recommend using glue for future projects. I think if you serious about the craft you have to be willing to try and do this right and not cut corners regardless if skill is not on the level. Practice does make perfect, but i always say it must be “good practice”.
I will also suggest trying to get the caliber of the movement its def Swiss and its most likely an A. Schild so if you can submit photos of movement we can try and pinpoint the manufacturer and caliber, you can then proceed on finding a donor movement which will be much cheaper and much less of a headache.
I think Gary has heard about pallet adjustment and the associated pain in all vital body organs.
His question is;  is there any way for a beginner to bypass the minefield?
Franky , I too am in his shoes .:pulling-hair-out: :fpc:
Regards.
The last time I needed to reattached a pallet stone, there was enough shellac left on the fork around the stone, that I just held the fork with my tweezers and put a flame about two inches above the end under the tweezers and it melted the shellac perfectly without needing any more equipment.
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
