What is this tool used for?
VWatchie
URMAKARVERKTYG
It's probably more than 50 years ago, but I still vividly remember this tool being in a drawer at my grandfather's house when I was a kid. I had no idea what it was or what it was for but I was for some reason intrigued by it and played around with it. I think I asked my parents what it was and they had no idea so, being a kid, I guess I didn't think it was any use asking my grandfather.
So, can anyone please tell me what it is and what it is used for? Thank you!
I agree with Tmuir, it's a glass cutting tool. First, you scribe the glass with a sharp and hard edge (like an industry diamond) and then you put your tool on the edge of the glass into any of the two cut outs in the tool depending on the thickness of the glass and rotate the tool so to "bend" the glass and hopefully the glass will break were you scribed it.
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
