Quartz submariner not working
markr
I got this little beauty  at a swap meet on Sunday.  I changed the battery and still nothing.  I know nothing about quartz. Is there a trick I kneed to know?  Is it worth taking down to be repaired?  Should I look for an ETA movement to put inside?  It does have the gold matching band in good condition.
If you can't easily find a replacement movement, then you might risk stripping off the dial and hands (assuming this is possible), and cleaning the mechanism in lighter fluid.
This *might* get it going, however if the coil or the circuit is damaged, then your luck is out, and you will need to keep searching for a replacement.
Edited by AndyHull
1 minute ago, watchweasol said:
Hi   might be worth a fiddle,  Swill out with Naptha and a spin on the line release. No dismantling that one.
I have fixed a couple this way... well slunged in lighter fluid and dried in front of an electric fan heater, but basically the same method.
Bear in mind that naptha/lighter fluid is obviously flamable, so take care not to set things ablaze when evaporating off the excess. :blink:
    • H Watch Repairers—is there is a ‘standard format’ for the service marks or codes lightly engraved inside cases of pocket watches or wristwatches?   Sometimes I can see there might be a reference to year/ month but other times am confused. I’ve included an image of the rear of a 1951 Hamilton 992B Railroad pocket watch as an example. Thank you for all information you can give, Mike
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
