Watch oils?
stevew
With so many watch oils available nowadays, with different ones for different parts of the workings, i have always wondered, what did they use years ago?. You see Clocks and Watches, still working sometimes, and obviously never had such advanced oils.
Obviously new improved lubricants come to be needed as finer( friction reduced) movements are manufactured. Hublot makes a multiple complication mechanical watch now, with fifty days power reserve, not neccessarily stronger MS, but less friction.
On the other hand, industry is to survive which some times neccessitate  abuse of the term NEW IMPROVED in adverts. Not to get into details of shroud bussiness practices.
Nano science is expected to come up with technologies to revolutionize lubricants as we know em today.
Many advancements have been made in the lubricating qualities of watch oils over the years, but perhaps the most important is how long they remain effective in use. That coupled with almost universally waterproof cases since the mid 20th century allowed a shift from having one's watch serviced every year or 18 months or so, to several or more years between servicing. When a watch is cleaned and reoiled every year then the old whale oil works very well (it really was from whales).
At the other end of the spectrum the senior lecturer at the school I studied told me when he was an apprentice the worst job that he had was making the grease for the tower clocks they looked after.
He had to go down to the butchers to collect all the offcuts and then they had to render the fat down to make grease for lubing the tower clocks. :startle:
Thank god now we can just buy a bottle of oil or grease.
Often quoted in Lee Child novels by Jack Reacher character is a substance called squalene.  A natural organic compound found in shark liver oil and olive oil, and was used by watchmakers to lubricate delicate mechanisms.
Also found on the sides of human noses !!   :hot:                   Not sure how long it would last before going rancid,  who nose :D!!!
I heard it said  that  whale  oil is still  unsurpassed  as a lubricant. At one time it was used in automatic  transmission  fluid..after they phased  it out here in the states there were for many years  a transmission  shop  on every  corner..
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
