Pallet cock
gary17
Hi
I have just started my first rebuild.
I'm hoping to get help.
I'm doing my first rebuild and i've come to the escape wheel and the pallet (the anchor thing with 2 jewels that interacts with escape wheel)
Do they just have to be placed on the jewel? I can see no hole within the jewel to accept the escape wheel or pallet.
It just seems very loose.
Is this correct or have i made another mistake
Thought i would ask before screwing down the pallet cock.
cheers
gary
14 minutes ago, gary17 said:
Hi
cheers
gary
Huh... Very odd that a pivot jewel would have no hole for the pivot. Can you provide a picture of the situation? Could it be a capped jewel but with hole jewel missing?
Edited by CaptCalvin
I think i've explained wrong,There's a hole with a jewel at the bottom of each hole.The pallet  and escape wheel both fit in the hole. but there no hole, In the jewel itself? So the escape wheel and pallet are loose fitting into there holes.
God i hope i've explained that better
apologies
gary
Edited by gary17
Have you looked at any YT vids of how a watch works? Sorry I don't have a link handy but there are a bunch, some of tge old ones from Hamilton and Elgin/ Waltham are superb, very clearly showing the function of each part with animation and everything.
If you can't see the hole you are not using a loupe.
Then if you see the hole, but the wheel or pallet fork fits loosely as in never finding its place , then the pivot has been snapped.
Edited by jdm
IMG_20190812_212534.thumb.jpg.7c7a038331d175ebfb4cca14ebdc7292.jpgHang on
See the two purple hole? the jewel holes? The escape wheel axle or arbour goes in to 1 hole. and pallet? or fork? axle arbour goes in other.?
The teeth intermesh escape moves fork or pallet which then in turn moves balance..
But both escape and fork are loose.
pics
13 hours ago, nickelsilver said:
Yes. But the pallets would line up with the view holes in green and I can't see anywhere else the escape wheel would go.
That's why I think the escape jewel is missing.  It should be in the hole circled by the left green circle.
RMD
4 hours ago, rduckwor said:
Then I see no obvious place for the escape wheel in the plate.
The beauty with escapements is the fact there has been so many different solutions throughout time, take for example the escapement in a pin-lever, sometimes you have them setup like a super duper co-axial speed racer.
So in this case one really can't tell what it is or how it is configured until he posts Pictures of the complete movement, before strip  or at least Pictures of the escape Wheel and fork.
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
