Custom Build using Venus 170
Here is all the info on the 'Brocot' suspension block and regulating arbor. http://www.ian-partridge.co.uk/brocotsq.htm
I usually don't read new introductions but when you came to the group did you want to learn watch repair? The reason I ask is your watch seems so suffered some damage under your hands. And now you're ready to move on to a new patient and have you learned? I often relate watch repair like learning to be a doctor lots of practicing. Even though this is a damaged watch have you practice taking it apart and putting it together a whole bunch at times so you feel confident that the next watch you probably won't break anything? Then when watches were invented specifically pallet forks they didn't have epoxy glue which even if they did they wouldn't you used anyway because the pallet stones need to be moved around they need to be adjusted. so the substance of choice for holding pallet stones and roller jewel's in is shellac. It's a really interesting substance were if it's warmed up at melts the palace on can be moved around hopefully the correct position when it cools shellac hardens back up in the pallet stone will be held in place. If you're carefully could probably put your pallet stone back just warm up the fork carefully ideally there's a tool for this and your pallet stone would be fine.
Hi @JohnR725, I would say its a happy end, the watch was in a much worser state and turned out quite nice(imho). I just hoped for a higher result after all that work. I agree with you, as long as it runs and keeps time, Im happy. Thank you for your advices!
The full article on that patent is a really interesting odd read. I wasn't aware that even a specific set of instructions on the use of a product could be patented. Does that mean that if i can prove that walking backwards will reduce shoe wear by up to 30% then i can patent that idea, and sue in court anyone i catch doing it ? -
The wheels turned fine. I set the escape wheel in the epoxy when it had just ‘skinned’ and wasn’t set, made sure it spun with the 4th wheel, and let it set. After cleaning I assembled the barrel and wheel train - all fine. Moving the barrel the escape wheel spun freely. I put a bit of 9010 in my epoxy setting. It went wrong when I put the pallet fork in. It wasn’t seated right (no jewels) and the escape wheel knocked a pallet jewel out. I have no idea how to reset a pallet jewel - epoxy again? I’m not spending any more time on this one - it’s missing hands and the front half of the case anyway, and I have more watches ready to put on the bench.
