Greetings from Sweden.
HSL
I'm Heikki Laitinen an enthusiastic watch collector from Sweden.
I have been collecting and servicing/repairing watches for some years now.
My passion is in watches from the 40's to the 60's but I enjoy working on anything from simple Timex movements to Chronographs.
I ended up here after enjoying Marks lessons and videos..
Thank you all for this warm welcoming!
I´m sure there are lots of wisdom in this forum when help is needed and maybe even I can help out with something.
Meanwhile I will read through the older posts and maybe even post an odd picture or two from my quirky collection of watches I wear on a random... nearly daily basis.
//Heikki
    • Back home...printing now.  Will report results
