my friend gave me a rotary to look at.he has had the battery changed by a jeweler? and it stopped after a day.the problem i have is getting the caseback off! there is a arrow > opposite the crown and a little indentation but i cannot get anything to purchase a grip.i have tried all sorts of tools to no avail and i am frightened of scratching the case. any suggestions? kind ones preferably! thanks B.
2 hours ago, berniethebolt said:
where did you obtain that beast?
I purchased this tool a few years ago. i think at the time Cousins was selling them. I have seen them on ebay. If you want a more slick tool and have a bigger budget horotec do this.
found the black one at red rooster £20,so will go for that and hope i need it again! thanks clockboy.B.
On 11/13/2018 at 6:54 PM, clockboy said:
I may be wrong but I did one of those last year. The case back was incredibly tight and I had to use one of these.
bought one of these(above) and struggled a bit until i took the blade off and used that on its own and hey presto it opened.next shock; there was no battery in the movement(?) my mate said he paid a jeweler friend £9 to fix it! i think he needs a visit!! could be he got confused.i will find out.any way the problem is now sorted for a couple of  quid:mad::woohoo-jumping-smiley-emoticon:
Edited by berniethebolt
missed word
On 11/23/2018 at 1:10 PM, berniethebolt said:
i see you edited your post,but i saw it first in my e-mail box! it is a ronda movement.thanks.B.
Ah yes, edited because I re-read your post and realised it was now working.
Didn't know Rotary used Ronda. Is it a recent model? The ones we have in the family are all Miyota but about 7 to 10 years old.
it looks pretty recent but i cant find it on the rotary website !
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
