An interesting question indeed!
This is speculation on my part as I don't actually know, but I don't think that "lift angle" has quite the same meaning on these balance wheel electronics as it does on conventional mechanical movements.
In a conventional mechanical movement energy is delivered to the balance from the escape wheel, via the pallet fork and impulse pin. The lift angle is the angle of arc through which the balance wheel rotates whilst it is receiving energy from the pallet, or the angle of rotation in which the impulse pin is in contact with the pallet fork (same thing).
In an electronic balance wheel movement the power goes the other way. Energy is supplied to the balance wheel by the energised coils acting on the wheel mounted magnets. The balance transfers this energy to the pallet fork which then pushes round the teeth on the escape wheel thus delivering energy into the wheel train. If you compare the escape wheel from your Elnix to one from a conventional mechanical you will see that the teeth are a completely different shape to allow for the reversing of the direction of power transfer.
You could argue that "lift angle" still has the same meaning as it is still the angle of rotation of the balance wheel through which energy is being transfered between the balance and the escape wheel. However, whether or not it makes the correct set of sounds for a timing machine to make sense of......???
I would try it out and see what it says. I suspect that it will be able to give you meaningful data for beat rate, beat error, and daily rate, but I'm not sure that I would have a lot of confidence in the amplitude reading. Even if it did give you accurate amplitude data, does it actually have the same significance as for a pure mechanical?
