Ok Guys, what is this for
jdrichard
More pictures would be helpful? It looks like a lathe attachment But can't quite see the rest of it to see what it might be used for other than it looks like it has at least one pulley. Then the three things that are hidden in the slots those it be interesting to see.
That’s all I got, but think it is a pivot polisher.
John, I too thought it looked like an attachment for a lathe.
It could possibly be a powered milling/drilling unit for machining watch plates that are held on a face plate in a lockable/ indexable  headstock.
I'm attaching an image I'm guessing that the shaft with the pulley on the end goes into the hole of the main unit. I got the idea for this from the catalog found at the link below. You can download a nice PDF a little light reading. Unfortunately I did not see the same tool in the catalog.
Then in one of the other books I have that lists tools it does resemble a pivot polisher. But the strange part is currently it has a centering piece in their which doesn't quite seem right for pivot polisher? Centering piece would be more for drilling holes except with all the adjustments this is way too fancy for drilling holes.
https://archive.org/details/20thcenturycatal00purd/page/n5
    • I used Google Lens on the pic and it suggested "motorcyle belt punch". And googling pics of that does show very similar tools. The end on mine is sharp, and does look suitable for punching holes in leather. I've no idea what belts on motorcyles would need piercing? The hole is about 1/4", so I cannot see a use in watchmaking. So, why have we both found one in a collection of watchmaking tools?
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
