“Replica” Rolex 3135 questions
Hi guys! I’ve just changed a watch battery for a friend of mine & he says it keeps stopping on him when he puts it on to go out, he says if he takes it off a pulls the crown & puts the crown back in the starts working again! Any ideas please! 👍
Sorry, when I said lift up: it tilts, lifts up on the side where the winding pinion is so the teeth no longer engage, down on the side where the mainplate is worn. I think it's worn there more than is immediately apparent in the photo; it's a bit dark. I shall get some photos of the crown wheel 😉
The stud has a neck that is a little smaller in diameter than the end and the hole is keyhole shaped so the stud locks in and I wouldn't need to worry about the thickness of the tail pulling it out of the hole. It might be possible to remove the stud from the existing spring, but I don't know how I'd go about doing that in such a way that it would be reusable. Maybe work around it squeezing with pliers until the riveted end became small enough to pass through the spring? A few more higher magnification pics of the pin/stud:
What's the movement? The fact it lifts up would make me think it's the wheel that's worn as the screw should set the maximum height. Can you post photos showing both sides of the wheel.
By Juleswatch · Posted
Nothing obvious I can see, I'll take a better look today. I thought so too, I thought maybe a button to remove the crown but not that either. The mystery continues...
