Sorry about the downtime today
Sorry about the downtime today. Tried to do an upgrade due to there being a security issue with the current version. Unfortunately so many errors presented themselves I had to roll back to a backup.
It then still would not play ball as some CSS cache files would not load (causing a broken look on the pages).
Going through all my backups I found the broken files and restored them individually one-by-one.
All seems OK now - time for coffee :|
Will try an upgrade again in a few days, first need to work out why it failed.
About another 1.5 hour downtime again this morning (from 3am UK time) and managed to sort out all the problems.
The website is now upgraded and secure again.
If you were kicked off while I worked on it - I apologise.
No need to apologize and thank for that great place/forum.
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Hi [mention=1]Mark[/mention]
Since your last update I can't connect with Tapatalk anymore
I have the latest version installed on the server.
I'm writing this with Tapatalk on my phone.
All seems fine.
Are you on the latest app version?
Anybody else having problems with Tapatalk?
Sent from my SM-G950F using Tapatalk
Hi again Mark.
I have :
1 - uninstalled and reinstalled Taptalk on both my Android Phone
2 - changed my password on watchrepairtalk
3 - tried to connect via Tapatalk
4 - failed with both phones
And no connection problems on the other forums via Tapatalk, only watchrepairtalk forum.
Edited by manodeoro
I even changed my email adress and password ... nothing worked
I really think the problem is with my account on this forum.
It's not a big problem as I still can connect with a computer but I'll be in vacation from 14/07 to 31/07 and I wont have access to a computer, only my phones.
So if you could try to see what's going wrong and solve the problem that would be really kind.
I've found that the specially tailored web interface for mobiles is so much better than Tapatalk, so I dropped the latter completely.
Faster, easier, full access to features and picture postings, no extra account needed. Thanks Invision developers.
Not easy to debug if I can't replicate your problem.
I will reinstall the plugin later and post when I've done this.
Tapatalk is a buggy piece of software and im getting tired of the malware aspect to be honest.
The IP board web interface is now very excellent so you do still have access via mobile.
If I create a new account and if it works on Tapatalk, do you think you can transfer my posts from the existing one to the new one ?
OK ... I've tried the IP board interface and it's OK
Edited by manodeoro
OK - I have completely deleted the Tapatalk plugin and re-installed.
Interestingly this broke my Tapatalk app and no threads would appear in the app on my phone. Closing and re-opening the app several times kicked it into shape and all seems well.
Give it another try if you can.
Working perfectly today [emoji4]
Thank you very much !!!
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
