Modern Fake or just average?
Tmuir
I stumbled across this clock and no I don't plan to bid on it, but was just interested in what the experts think as to when this clock was made.
Its certainly no earlier than the 1920s or 30s, but I suspect much later.
The enamel dial looks a pretty average finish and the nuts and C clips make me think its a modern clock (Within the last 20 years) made in the far east.
Would I be correct in assuming so?
Just trying to broaden my knowledge on what is genuine and what isn't.
https://www.ebay.com.au/itm/Superb-Vintage-Enamel-Mantle-Clock-Cloisonne-Pendulum/253716467326?hash=item3b12ae0e7e:g:dOAAAOSw~R1bNJ5q
Yes I think you would be correct in your assumption that its no more than 20 years old, it has zero quality the castings are the roughest I have ever seen so I think its far east in origin, yet it already as four bids, its a total waste of money at any price.
Modern, more than likely from China. The Cloisonné is very poor, you can see it is applied in stripes, no wire visible, antique you would see between the individual pieces.  The C clips are a modern invention, there holding in the arbors. Poor quality movement. Because I’m a mod, I can’t say what I would like to.
5 hours ago, oldhippy said:
With the barrel arbors held in with those clips, makes it easy to remove the barrels without taking the rest of the movement apart. Even through the movement is not a good one it has a good point.
Agree easy strip Oldhippy, but personally I would not trust them, just me..Like when they make a half moon cut out in the plates for the wheels etc, just cheap and nasty.
2 hours ago, oldhippy said:
I do not like modern clocks or fakes. In my time if it wasn't the proper thing I would not undertake the repair.
Agree the far east etc seem to copy everything, and produce cheap items although people do buy them.. Not me I must add....
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!?
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
