Ebay flooded with Carriage clocks from China
oldhippy
I've sent him the same, now he has a idea its fake if he sells it he is technically committing a fraud.
His reply:
"hi now i did not now thank for letting me now thanks" (his spelling not mine)
Lets see if he takes it off sale
Edited by wls1971
He has removed it.
These are his replies to me
Question Why have you described this clock as a very rare clock saying it is buy HUGUENIN A PARIS. When it is a Chinese fake.
Answer HI IT HAS IT ON IT THANKS
Question So you believe everything that has writing on it to be true. How bloody naive you are. So you don’t mind ripping people off.
Answer HOW DO YOU NOW IT IS FAKE I HAVE A VERY GOOD RATING THANKS
Question Simple. There has only ever been one made by Huguenin. Compare the genuine to the rubbish you are fobbing off. Look here.
http://www.my-time-machines.net/Huguenin.htm
Answer Ok mate I have taken it of
Well at least he's done the right thing now.
This one sold for £1,000 at auction, the trade has become wise to them, they are now fetching between £150 to £300 in the salerooms but occasionally they fetch much more from ill informed bidders.
https://www.the-saleroom.com/en-gb/auction-catalogues/londonauctions/catalogue-id-high-r1-10056/lot-56f6e663-4af0-4519-b665-a7a100df2875
The going rate shipped new from china is $200.00
  • 7 months later...
What kind of watch?
https://meshok.net/item/241378721_%D0%A7%D0%B0%D1%81%D1%8B_%D0%9D%D0%B0%D1%81%D1%82%D0%BE%D0%BB%D1%8C%D0%BD%D1%8B%D0%B5_%D0%9A%D0%B0%D0%B1%D0%B8%D0%BD%D0%B5%D1%82%D0%BD%D1%8B%D0%B5_%D1%81_%D0%B1%D0%BE%D0%B5%D0%BC_%D0%9A%D0%B0%D1%80%D0%B5%D1%82%D0%BD%D1%8B%D0%B5_19%D0%B2%D0%B5%D0%BA_%D0%A0%D0%B5%D0%B4%D0%BA%D0%BE%D1%81%D1%82%D1%8C_%D0%A1_%D0%A0%D0%A3%D0%91%D0%9B%D0%AF
  • 6 months later...
The easiest way in telling the difference between Chinese and French carriage clocks.
Chinese the strike work is always on the back plate, holes in the bell, screws poor and a very dark blue and mostly cheese head, very poor brass if you can call it brass. Platform escapements cheap looking and many look like they are made of poor soft metal. Many Chinese carriage clooks come with a centre seconds the hands are poor looking and not well finished. You don’t come across the French carriage with centre seconds but the do exist. Chinese carriage clocks that have painted panels are poor quality bad detail and most likely painted by children. The French are suburb with detail and the finish can be most delicate.
Here are a few photos of the Chinese rubbish and a few of the French good quality movements.
If you are thinking of buying such a clock let me know and I can advise you about it
1 and 2 Chinese 3 4 5 French
  • 3 months later...
A spectacular piece of crap.
 Made in China
The seller says it’s a  Double Fusee, Victorian (1837-1900), Time Period Manufactured:
1800-1900. Price £550.00
More like 10 years old.
https://www.ebay.co.uk/itm/115377271906?hash=item1add057462:g:ua4AAOSws0RieRMq
Edited by oldhippy
 Made in China
Did you make a reasonable offer to the seller?
3 hours ago, oldhippy said:
Here are some photos of the crap.
KarlvonKoln, I bet you wished you had bought it after seeing how wonderful it is. 🤣
Hmmm.  Well, people tell me I should careful what I wish for.  Sage advice at times.  At least the case is kind of interesting.  Not what I'd go for, myself, but interesting.  And I'm not as knowledgeable with clocks as you are, OH, but that movement doesn't seem to jive with the description of what I thought I would see.  It sure doesn't look Victorian, like it has been aging that long.  Not to me anyway.  Sometimes I look at a thing for sale, and a little voice tells me what kind of beer I could buy with the same money, and I end up getting the beer instead.  This is the kind of clock where I would bring home beer.
I couldn't understand why there were so many of these clocks on eBay, until the other night when I attended a talk by Richard Price on French Carriage Clocks, where I found out just how much they are worth, he had about 20 on the table and none were under a grand, no wonder the Chinese got into faking them. And the shysters got into selling them on eBay, were the fools go to be parted with there money.
What did they use to make the moldings?
Did they just get another clock and press it into Plasticine and then pour plaster of Paris in that and paint it gold?
I've never seen such hideous brass casting on a clock before.
'Superb Antique Enamel Mantle Clock With Key Working'
I'm assuming the Enamel he is referring to is Humbrol. 🤣
Again the casting is total crap, done with a blunt stick and plasticine.  People will buy this crap as genuine and in a year or two put it back on the market at a higher price. If you know nothing about clocks in general it probably looks ok . I personaly dont buy clocks on the net I like to see them touch them and inspect them warts and all. Too much crap on the net as Old Hippy finds out (a practised eye).
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
