Stuck Screw Back
Hi everyone,
I know there has been previous topics on this but I have a Armani watch a customer brought to me to replace the battery and a stem. I have tried everything and nothing will budge it now my question is on super gluing a bolt on the back of the watch. I know you soak it in acetone after the back is off to remove the bolt and get rid of the glue. My worry is that once I glue this bolt on that it still wont move and if that is the case then how would i remove both the bolt and the super glue because i cant soak the whole watch in acetone for the obvious reason. Im also open to other suggestions as i have used every tool and trick i can think of.
Thanks
What does the caseback look like? If its the standard 'water-resistant'  threaded type,  and you've tried a Jaxa wrench with no success, gluing a bolt onto the back does indeed work. I usually do it with JB weld epoxy which forms a very strong bond and it has always worked. Getting the bolt off requires heating it up with a pencil tip butane torch (!)
Using superglue should work, but if it doesn't you can always take a glass eye dropper and place a few drops of acetone around the bolt to get it off. My concern would be if the superglue DOESN't work and the bolt just pops off of the caseback when you apply wrench torque.
J
Thanks, yes it is your typical water resistant threaded case back that has not had a battery changed on it. Guy bought it about six months ago so it is tight from the factory. Never thought of using an eye dropper, thanks for the info im going to try the super glue trick first and go from there
Do you know a friendly watchmaker with a Big Bertha? That’d be the way to go if at all possible. They really are stupendously good.
Normally glue a nut on rather than a bolt.
Once off I just put some super glue remover in the centre of the nut which acts as a well and leave it a while to slowly seep out over some hours.
Guess you'd be able to do that even if the back didn't come off.
Sent from my Moto G (4) using Tapatalk
Yes indeed. I've used bolts, but a nut is easier to work with although I've only used Epoxy which definitely works. The caseback might get a little residue stain on it, but you can sand that off with superfine grit paper.
J
No stains when using superglue and no need to use abrasive paper. The remover softens the glue so easy to get off with your nails.
Also find it easier to leave the super glue set over night and use a small socket driver rather than spanner. This allows you to exert a little downward pressure when un screwing the nut which normally helps in my experience.
5 hours ago, fuse63 said:
Hi everyone,
Everything like what? Picture of the watch and which tools have you used?
  • jdm locked this topic
  • Mark unlocked this topic
All off-topic posts removed - this is how it will be from now on. Please please please keep threads on topic out of respect for the OP. Please please please - no bickering, and that goes for everyone.
It makes our forum look bad - we are a group of great people, we can keep it that way.
If anyone spots this happening again from now on - please report the post - there is a link above every single post, I will be on it like flies on a turd. :D
now - back on topic, pretty please ;)
GOOD DAY MARK. THANKS!
REGARDS,
J
I have a titanium case with a titanium back (dumb) that is probably galled together. Respectable brands use a stainless cover on a ti watch so they don't gall.
Anyway, my plan is liquid nitrogen. I will place the cover wrench on, fill the center with liquid nitrogen, wait a fe seconds and try again.
If that doesn't work, I may try JB weld although I'm not sure how it will hold up at super-low temps. Note on this watch I know the male thread is on the cover, so shrinking it back from the case with the nitrogen should work (in theory).
It's in "the pile" to get to at some point...
    • I used to be quite active on The Lotus Forum when I owned my Esprit. I was there for so long, Bibs asked me to be a moderator. I'm not sure how long I did that for, but I think I turned into the second longest serving moderator. When I 'handed back my keys', Bibs made me a Full Forum Member. Normally this is a paid membership. My reward I suppose for helping out for many years. Bibs (forum owner) is quite active on there and if I am not wrong, don't quote me in other words, I think he once said that the money from memberships didn't cover the running cost. He adds money himself to keep it going. Does Mark have any sort of subscription scheme on here? I'll admit that I never paid to be a member on TLF. I should have. I never did. I agree that it would be a good idea that there is some sort of contingency plan for this forum. I intend on becoming more active on here. Life has just been getting in the way recently. I enrolled on Mark's watch course and was keenly doing that, but even that has had to take a back seat for a while. I am looking forward to getting back into that and also starting to do work on the clocks that I have been amassing. To do that successfully, I see myself needing to lean on the other members here. If for whatever reason this forum was to close, I think a great many of us would struggle.
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
