My first steps in the dark arts
Pip
Since I’ve started tinkering I’ve considered hairspring manipulation to be some kind of black magic witchcraft, practiced by watchmakers who are quite probably in league with the Devil. So of course, it was only a matter of time!
Had a spare half an hour or so yesterday so I pulled out a mangled hairspring I’d put aside which was from a Seiko 6119 iirc, and set about it.
I’m by no means finished yet but I found the process both frustrating (trying to move the twisted coils to get to the one I wanted to manipulate) and very satisfying when one loop goes back about where it should.
If anyone has any hints or tips feel free to shout!
I started with this:
Took it off the balance to reveal:
And after half an hour or maybe a bit more got here:
I’m pleased so far but won’t get another chance to tackle it until the weekend.
I also have another one that is lovely and concentric but is a fantastic cone shape. No idea yet how to tackle that, but I’m sure some of you will point me in the right direction.
you have done well there to get to that in half an hour , it is definitely one of the more challenging and frustrating aspects of watch repair.
i believe the method for a coned hairspring is to hold the collet and the outer coil and pull through the spring in the opposite direction, good luck with it all.
   there are videos AND  books that show "this art".   vin
  • Confused 1
I had a hairspring that was badly coned. You have to stretch it a LONG way before you have any effect on the shape. There's a risk it will break at the  collet.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Can we help with what you are trying to  figure out?
    • In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
