Great book on adjustment
Just found a great book on rules for watch timing.   Rules and Practice for Adjusting Watches  by WALTER J. KLEINLEIN  author of Practical Balance And Hair Spring Work. This book goes much more in depth than DeCarle and others. Actually breaks down for beginners and highly skilled workman. The beginner section is broken down and explained in depth step by step for each position and what to do if in the minus or positive in each position. Also gives hundreth of millimeter side and end play for each train gear and pallet and escape wheel. Wich I have always wondered how much was correct and never found anywhere else. Highly recommend for bench top reference.
getting ready to drop the hammer on a stereo microscope wich magnefication do you guys think is best. most recommend 45x and the other half say 90x. any advice will be greatly appreciated. want to have enough power to check for chipped jewels but still have enough working height.
I have one with two different eyepieces (pairs), a 10x and 15x, and the scope itself has 1x and 3x, giving a total of 4 magnifications, 10x, 15x, 30x, and 45x. I find 30x to be optimal for being able to see what I need and still have room under the main lens to work.
  • 6 months later...
Wow, stereo microscope?  Here I was thinking I was a Big Kahuna for ordering an electronic timing machine...
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
    • for the most part no. Each individual watchmaker and/or shop had their own system. One of the shops I worked at basically had a reference to a page number in a book. then there are some shops that do no markings at all as they keep their records on a computer and they don't have to mark the watch. Usually if somebody is marking and they've service the watch before you'll see those next to each other. then as far as anything resembling a standard goes at one time the American watch and clockmakers Institute assigned all of their members a number. but that was a very long time ago and I doubt that they are using it anymore.
