Strange Lathe Thread
jdrichard
I have a Boley Leinen Reform Lathe that has a nut that you adjust to tighten and loosen the lathe spindle bearings. The thread on the male part of the spindle shaft are flat on the top. Like the top of the mountains have been chopped off. The mating thread on the nut also has the mountain peeks chopped off. Any guess what the reason. The TAP is a 1/2” 20 TPI SAE. And i need to make a nut that is tighter fitting.
Also, is your plan to make a lock-nut to bind the existing nut against?
Replace an the existing nut with one that binds. Almost done: Update3f31b917a9655cba8a1fc9d2e0c6f183.jpgb2c556ff6c46f3b92effb614b0c56109.jpg323e2c54ac26e6dcf9aef3ab5bad2db3.jpg34dbc14cf344fef5409a8adb67e78695.jpgFlattening the peeks
Still need to shave it down a bit and then cut it on one side and compress it slightly
How springy is brass and should i heat it before i compress it a bit?
On 16/03/2018 at 1:16 AM, jdrichard said:
This is the start of my alternate nut that i need to complete and tap and somehow cut the peeks off the mountains.
it looks like something called a butress thread
17 hours ago, jdrichard said:
Interesting. Wide thread makes it mot durable.
    well,  the point is,  it is not a simple or a common thread.  "by any other name"  it's not easy to  duplicate without a machine shop.  vin
On 3/16/2018 at 6:31 AM, rodabod said:
A German lathe with an American thread?
no kidding....I'd almost be willing to bet the lathe its a 12 x 1.5 thread.   Give a 12 x 1.5 tap a try.
Acme?  Buttress?  easily identified with a straight on shot of the male thread but I'll go double or nothing on the lathe bet they're not :).  If anything it would be trapezoid because its German but the pitch is way too fine, and there is no reason for it in that application.  Afaik you don't see many buttress threads outside of collets and the odd vise screw.
Why do you need the nut tighter?  Afaik its suppose have two nuts so you can lock them, i.e. staying in its spot isn't a function of the nut being tight on the shaft.  You can't really have a nut tight on a screw, there has to be clearance or it won't turn.  If its sloppy, that means too much clearance - you need a tap with a smaller pitch dia (taps are sold for the different classes of thread fit).   But i'm betting the issues the wrong thread identification.
If you did want to make it tight on the screw, you'd have to split, pry it open slightly, then thread which you can do with a tap.  Its not really a practical solution imo....when you do have to lock a nut on a thread you do so with small set screw with a brass underneath (ala Schaublin and Aciera)
End of the day I'll bet the solution is simple - a 12 x 1.5 nut that fits much better.  Make two so its a lock nut arrangement :)
Edited by measuretwice
Acme?  Buttress?  easily identified with a straight on shot of the male thread but I'll go double or nothing on the lathe bet they're not [emoji4].  If anything it would be trapezoid because its German but the pitch is way too fine, and there is no reason for it in that application.  Afaik you don't see many buttress threads outside of collets and the odd vise screw.
End of the day I'll bet the solution is simple - a 12 x 1.5 nut that fits much better.  Make two so its a lock nut arrangement [emoji4]
I think i found the final solution
So i could buy a 12x1.5 nut, correct? And cut it and make it sprung. The nut hole is a 29/64 inch prior to taping.
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
