Strange Lathe Thread
jdrichard
I have a Boley Leinen Reform Lathe that has a nut that you adjust to tighten and loosen the lathe spindle bearings. The thread on the male part of the spindle shaft are flat on the top. Like the top of the mountains have been chopped off. The mating thread on the nut also has the mountain peeks chopped off. Any guess what the reason. The TAP is a 1/2” 20 TPI SAE. And i need to make a nut that is tighter fitting.
Also, is your plan to make a lock-nut to bind the existing nut against?
Replace an the existing nut with one that binds. Almost done: Update3f31b917a9655cba8a1fc9d2e0c6f183.jpgb2c556ff6c46f3b92effb614b0c56109.jpg323e2c54ac26e6dcf9aef3ab5bad2db3.jpg34dbc14cf344fef5409a8adb67e78695.jpgFlattening the peeks
Still need to shave it down a bit and then cut it on one side and compress it slightly
How springy is brass and should i heat it before i compress it a bit?
On 16/03/2018 at 1:16 AM, jdrichard said:
This is the start of my alternate nut that i need to complete and tap and somehow cut the peeks off the mountains.
it looks like something called a butress thread
17 hours ago, jdrichard said:
Interesting. Wide thread makes it mot durable.
    well,  the point is,  it is not a simple or a common thread.  "by any other name"  it's not easy to  duplicate without a machine shop.  vin
On 3/16/2018 at 6:31 AM, rodabod said:
A German lathe with an American thread?
no kidding....I'd almost be willing to bet the lathe its a 12 x 1.5 thread.   Give a 12 x 1.5 tap a try.
Acme?  Buttress?  easily identified with a straight on shot of the male thread but I'll go double or nothing on the lathe bet they're not :).  If anything it would be trapezoid because its German but the pitch is way too fine, and there is no reason for it in that application.  Afaik you don't see many buttress threads outside of collets and the odd vise screw.
Why do you need the nut tighter?  Afaik its suppose have two nuts so you can lock them, i.e. staying in its spot isn't a function of the nut being tight on the shaft.  You can't really have a nut tight on a screw, there has to be clearance or it won't turn.  If its sloppy, that means too much clearance - you need a tap with a smaller pitch dia (taps are sold for the different classes of thread fit).   But i'm betting the issues the wrong thread identification.
If you did want to make it tight on the screw, you'd have to split, pry it open slightly, then thread which you can do with a tap.  Its not really a practical solution imo....when you do have to lock a nut on a thread you do so with small set screw with a brass underneath (ala Schaublin and Aciera)
End of the day I'll bet the solution is simple - a 12 x 1.5 nut that fits much better.  Make two so its a lock nut arrangement :)
Edited by measuretwice
Acme?  Buttress?  easily identified with a straight on shot of the male thread but I'll go double or nothing on the lathe bet they're not [emoji4].  If anything it would be trapezoid because its German but the pitch is way too fine, and there is no reason for it in that application.  Afaik you don't see many buttress threads outside of collets and the odd vise screw.
End of the day I'll bet the solution is simple - a 12 x 1.5 nut that fits much better.  Make two so its a lock nut arrangement [emoji4]
I think i found the final solution
So i could buy a 12x1.5 nut, correct? And cut it and make it sprung. The nut hole is a 29/64 inch prior to taping.
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
