Hamilton Electric 14K Nautilus 200
wetbird
Interested in knowing, if paying out $350 for the repair of this watch would be practical. An estimate valve (to a collector) would help me make a decision about having the restoration preformed. Any estimates of the value would be appreciated.
Thank you.
Thank you.
imageproxy.php?img=&key=77f0dcc5ac0f9d5b
Pictures are required please.
Thank you.
That imageproxy link doesn't seem to be working.
J
Thank you.
While I'm no expert on this type of watch, I do think that this is the best-looking model of the Nautilus watches. It also appears to be the first one, made in 1963. There's a book by Rene Rondeau, "Watch of the Future", that is all about the Hamilton Electrics. It contains images of what might be all of the Nautilus line. That it is a 14K example, and in what looks like excellent condition, I'd say it might be worth it. Is the back gold as well, or is it stainless steel? I don't know that there is a huge demand for these right now, but it might picking up, being that they are examples of the fashionable mid-century styles.
A check of Ebay might be your best bet for figuring a market value for this watch.
Working on electric watches seems to be a rather in-demand specialty. I happen to be working on my first one now. Fortunately, I have the service manual. Otherwise I'd be more doomed towards failure. I'm almost through reassembling. Fingers crossed. Good luck.
Edited by MrRoundel
Correct Typo
While asking if paying out $350 to get this watch repaired is practical , is something you would have to decide  for yourself .  It is probably the first Nautilus electric , being of the 200 series , and it is 14K solid gold , [a Big Plus ] , and it is in great looking shape . The Solid gold Hamilton Electrics Do hold their value .
  Having said that , I have a few Hamilton electrics in my collection and I have made repairs and serviced both the 500 and 505 movements . The later 505 movement is by far easier  to repair and service , and most Nautilus watches had that movement  . The 500 is tricky to repair because of the proper and delicate alignment of the 2 contact fingers .
  I would suggest that you get as much Information on the type of movement in your watch and contact members of the Hamilton Forum with questions as dadistic suggests .
Also you may want to contact Ebay seller adamtime with any questions . He always has all things Hamilton Electric for sale .
adamtime (758)
100% positive feedback
In the past I have emailed Hamilton Electric Guru , Rene Rondeau  through his website with questions , and he is a gracious Gentleman that will answer your questions .
Good Luck Wetbird  , and let us know what your outcome is .
    • I think that a 814/825 stem would work, there are a lot of compatible parts between these.
    • Hi everyone, I put together a Venus 178 recently, but found that the hour counter "creeps" ie. runs when the chrono is disengaged. This is the similar type of setup as the Omega 861, where the hour counter is driven off the mainspring barrel, but stopped when the chrono is disengaged by a friction spring.  Am I correct in assuming that the friction spring for the hour counter driving pinion should be dry? I am guessing that the issue will be either the spring or the driving pinion, but while the driving pinion has some wear the spring looks decent.  I've attached a couple of photos in case anyone has any tips. Thanks in advance!
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
