Longines ETA 210.001 battery.
rogart63
Had a Longines in for a clean and new stem and crown. A very  ultra thin quartz  that  I only have heard bad things about this movement . The movement plate is so thin that is easily will bent if watchmaker press the battery in to hard. But nontheless i got it running. For 3 month . No it's dead again . Haven't got it back yet. But see that there is a few different options which battery it should have. I put in a 341 as the spec says. But see that it could have a lithium battery also.  Could it be that my movement needs a lithium to be able to last a year at least.
http://www.startimesupply.com/product/ETA210001.html
Edited by rogart63
A silver oxide cell is what is needed for this movement. I don't know where you're seeing something about a lithium cell? I'm pretty sure there's none in the size of a 341 and the voltage would be too high besides.
It might just be a dodgy cell, it happens sometimes even with the good brands, for no rhyme or reason. The second possibility is friction caused by over-oiling since I believe these are one of those temperamental ETAs that likely operate best on a very finite amount of oil on the gear-train/motion work. Maybe the hands are simply touching as they pass, or perhaps some other fault has occurred since you last worked on it.
Edited by Ishima
According to ETA there's only two batteries for this 341 or the 346. Zero mention of lithium and their information is up-to-date as to 2016. Then I know I've seen one other small watche that did have an option either way of the batteries but I'm sure the circuit board is marked as the type of battery needs. Then the super tiny batteries they have a limited life unless it's fresh that's going to be a problem.
I have used a Renata battery. ETA says 43 month with the 341 battery.
I looked at ranfft and they say a lithium battery? http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&ETA-ESA_210_001
They are pretty easy to take apart . As almost all parts are on the inside the case. So will remove and see if i can get it running again. If it isn't the battery that is dead.
It was very dirty when i got it. So maybe there could have come som small parts into the rotor.
There appear to be three different versions of the ETA 210 Interesting also the size differences three movements so the specifically listed as this    9´´´ ETA 210.001  & ,9´´´ ETA 210.011 Both of these require either the 341 or the 346 battery. A third version is 10 ½´´´ ETA 210.411 Different in size slightly bigger and the batteries the same 341 or 346 and Battery: "Lithium" type U = 2,1 V Ø 7.90 mm, height  1.05 mm. Capacity 8 mAh Renata 44. I suspect you're going to find that the number 44 battery doesn't exist anymore.
I would first check the battery for voltage. I only use Renata or Seizaiken batteries because the cheapos tend to leak or just run out of power very quickly.
Some of the Renata cells I’ve use drop off quickly after the expiry date. Not so the Seizaiken.
Maybe I’ve been unlucky.
Neil
My 2 pence worth......
It could just be a faulty battery
You ideally need a consumption test doing on the movement, every watchmaker that does quartz watches will have a way of testing the consumption, I would suggest you take it to someone local and get it tested if you can't test it yourself. As you already say these movements are very flimsy and the plate can easily be bent, normally either someone putting the wrong thickness battery in or putting too much force on it whilst fitting it. There is a very good chance someone in the past has done this.
It may need a service, cleaned and a very fine oil like 9030 on the pivots, don't over oil it or the consumption will be high.
If after servicing it the consumption is still high and you are sure everything has been checked, scored pivots, bent wheels, end shakes, etc, I would guess the plate or bridge is bent, this is very common with this movement and would suggest a movement exchange or send it to swatch and they will movement exchange it as part of a service.
I wouldn't recommend buying a second hand movement off eBay as chances are you will have the same problem.
That looks like a pricey movement. I can see why you want to save it.
On the subject of oil, I bit the bullet and ordered some Moebius Quartz Watch Oil. I think my Nye was OK, but I understand, as was mentioned, that it doesn't take a lot to stop a quartz movement. Plus it sounds like the quartz oil was formulated to be thin, but stay in place without migrating. Admittedly, I cleaned and oiled an ETA 955.114 last week and used the Nye watch oil that I have. The watch is now running well. It's my friend's watch so I'll hear about it if it gives him grief, burns out batteries quickly, etc. Good luck, rogart63. Cheers.
Update a little. Not sure it will work forever . But it's working again. Had the rotor and wheels out. But there is some movement on the small wheels up and down so not sure it will last forever. maybe the plate is bent? But at least i got it running again . DSC09373.thumb.JPG.0a11910a0c3df13d816a90aad6b64c36.JPGDSC09372.thumb.JPG.119787e2901d0ca0615e0ebbe4bb05cb.JPG
    • I used to be quite active on The Lotus Forum when I owned my Esprit. I was there for so long, Bibs asked me to be a moderator. I'm not sure how long I did that for, but I think I turned into the second longest serving moderator. When I 'handed back my keys', Bibs made me a Full Forum Member. Normally this is a paid membership. My reward I suppose for helping out for many years. Bibs (forum owner) is quite active on there and if I am not wrong, don't quote me in other words, I think he once said that the money from memberships didn't cover the running cost. He adds money himself to keep it going. Does Mark have any sort of subscription scheme on here? I'll admit that I never paid to be a member on TLF. I should have. I never did. I agree that it would be a good idea that there is some sort of contingency plan for this forum. I intend on becoming more active on here. Life has just been getting in the way recently. I enrolled on Mark's watch course and was keenly doing that, but even that has had to take a back seat for a while. I am looking forward to getting back into that and also starting to do work on the clocks that I have been amassing. To do that successfully, I see myself needing to lean on the other members here. If for whatever reason this forum was to close, I think a great many of us would struggle.
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
