Help Cutting Threads on Stem
jdrichard
I am making a watch stem and am at the final step of cutting the threads. So I have a Swiss (probably Chinese) die plate and clamped the part in my lathe. The die did not cut the material AT ALL. So the stem is made of blue steel. Do I need to soften the blue steel before i cut the thread? I also just bought another die plate just in cast the one I have is dull.
I do this with blue pivot steel. First annealing the steel to make it easier to turn and cut the thread.
https://www.watchrepairlessons.com/2011/07/17/vintage-rotary-repair-making-a-new-winder-stem/
I think you'll need more heat than that. A small butane torch should do the trick....
What colour do I need the steel to get and do I just let it cool down at its own pace. Then once I cut the threads, do I reheat it to blue and quench it quickly in water. I think I only need to do the threaded area of the stem, correct. Have never done this before.
Annealing requires you to hold at the critical temp for a minute or two (for small parts) then a slow cool for a full anneal.  Overnight in ashes is ideal, shorter may work but for a full anneal it needs a very slow cool, so I've always done the box of ashes thing.  To heat treat it again, heat to critical temp (1450), hold for a bit then quench in appropriate fluid (will depend on the steel).  After quenching, heat to the desired tempering temp to 'let the steel down" - this reduces the hardness a bit but also reduces the brittleness.  The following colour chart is based being viewed in sunlight, ie they'll all seem brighter with the lights out.  The right temp is often called bright cherry red, which I always thought was a poor description given the ripe ones are lot darker than you want the steel
http://www.stormthecastle.com/blacksmithing/images/color-of-steel/forging-and-tempering-colors.jpg
Edited by measuretwice
I'm not an expert in this by far but red hot at least for both annealing and hardening, let cool for anneal and quench for hardening. The exact temperature depends on the material, and that's the hard part. There's a ton of information on the web about it, YouTube especially. I have a feeling your die may be at fault also, if it's anything like my die plate (again probably chinese) it's not good for much besides re-threading a buggered thread. Finding actual quality dies for our work seems to be one of the very hardest things to come by. Sorry I can't be of more help.
 Cherry red for a couple of minutes should do it. Taper the very end of the stem so that it can reach into the die plate.
Turn the stem by hand whilst it’s clamped in a lathe collet. Use an empty tailstock to push against the die plate so that it’s perfectly perpendicular to the stem.
Harden the stem to straw (or whatever hardness you prefer) and then polish.
see post above.....a slow cool means a slow cool - like overnight.  less will work, but a complete anneal is hours and hours of ramp down.  Just heating it up and letting it air cool is essentially air quenching it.   Google O1 heat treat cycles and note the ramp times.  Heat it up bright red, hold it there and drop it in a box of ashes is how I do it
edit window closed and I miss a bit....I'm giving the way to anneal carbon steel.  A shorter, simpler cycle might anneal it enough, but the point is if its not working its because you are either not getting it to the critical temperature, or more likely its not being cooled slowly enough.  A BIG advantage to to doing a full normalizing (think slow and full anneal) is that the stresses are removed.  Without that, there is an increased chance of cracking at the stress riser (ie bottom of the V thread) when you do the quench to heat treat after machining
The metric HSS set I suggested recently in the other tap and die set is great. It’s the 31 piece set which comes under various brands. Don’t bother with the shitty Indian die plates. Though a Martin Swiss die plate should work well if you can find one.
For annealing small parts like this, you need to keep heating as you cool it down to bring the temp down gradually. I found that you don’t need to do that for long - say one minute of gradual cooling.
Bargain! I paid £40 odd in the UK. Mine was branded Tool Station or something like that. It’s  a nice quality piece of kit.
Same manufacturer in china. Check out aliexpress app and buy from them first, free shipping as well, mist of the time.
On 1/29/2018 at 8:32 PM, rodabod said:
I've had the same set for years. Pretty much hit-and-miss when it comes to quality. I've bought a few separate dies and taps for the smallest three sizes, also on ebay. Even though more expensive, these were not necessarily any better, sigh.
Just need to find a reasonable priced professional tap and die set for us watch guys
Sent from my GT-N5110 using Tapatalk
    • Drat and double drat i was looking forward to the royalties on that idea.
    • Compression Spring Various Size. This might be helpful. I have watch furniture restorers and how they go about this problem, they inject glue underneath with a syringe and clamp it, leave over night. Next day remove clamp and it smooth. You could use an iron but be careful not to burn the wood.  https://www.ebay.co.uk/itm/265697329513?chn=ps&_ul=GB&var=565484998457&_trkparms=ispr%3D1&amdata=enc%3A1jd_-94ilTHWZLQ3PxHeC1A73&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=565484998457_265697329513&targetid=1647205088320&device=c&mktype=pla&googleloc=1006662&poi=&campaignid=17206177401&mkgroupid=136851690655&rlsatarget=pla-1647205088320&abcId=9300866&merchantid=119334104&gad_source=1&gclid=Cj0KCQjwir2xBhC_ARIsAMTXk849TnBArEYdgv1DpHf_somCZYmB7ViqD3UtvNJJc_dn4kj0AFxBXngaArSAEALw_wcB
    • 🤣 i think your first statement is rather dramatic, but i will take it in good humour.  I think the thread speaks for itself John.  What we are aiming for and when i say we, thats not actually that many that have spoke up. Is to have a back up plan to keep members in touch in case the forum ever disappears. So in essence yes the group has maybe taken on a life of its own and would like to remain together forever ( 🤣 i can also be dramatic )  maybe more members need to give some input of how they feel about it or say they are just not that bothered.  Either way at least the question gets answered. Can i ask what the forum means to you and how you would feel without it ? Thats one answer Rich from one person, without knowing how others feel the thread was just a waste of time. Aw Rich are you saying you'd miss me ? I'm touched 🙂
    • you should go to the European patent office and look up watch patents. I'm guessing it's probably impossible to make anything related to watches without stepping on somebody's patent it's good that they expire with time. They've literally as far as I can tell patented everything and anything. this is why is pointing out their other formulas for the Epilam I'm pretty sure Rolex might have their own formula for instance. somewhere in the universe I was once reading things that were rejected for patents for basically this kind of thing. So yes there is rules on what can and cannot be patented but I'm sure things fall through the cracks.
