Greetings, all.
Now I have experience with a few different types of shock-protection devices. Incabloc, Shock-Stabil, and now a mystery three-armed spring that I haven't identified. Is there a tip or special tool for installing those three-armed monsters?
Truth be told, I lost the hole-jewel/setting during cleaning in a semi-freak accident. I ordered what looks like the right one for the Gruen 505-6/Std 96-4 movement and set it in the surround. Trying to manipulate the spring in is giving me fits. Is a special took advisable for this? Any help is appreciated. Thanks ahead of time. Image attached of what type of spring it is. Cheers.
Found one of these on a Baumgartner movement (158?) installed in a Sicura.
It is tricky to work with it but not if you improvise a bit.
In situations where parts might jump around and get lost I place the movement in a transparent plastic ziplock bag and then work on the movement like that.
One advantage of the bag is that you can use it like some sort of rodico (minus the sticking part) and press lightly on the components at hand so that they won't move or jump around.
You can already insert one of the feet into the recess by sliding it in/underneath and when you do that try to position the 2nd foot into the spaced out slot that allows it to fit inside/underneath the incabloc system. Then rotate and do the same with the third.
That's how I did it.
Thanks, Chopin. I actually had two of the arms in, but the third one seemed to be fighting due to the height of the jewel, or? I like the plastic bag idea a lot. I may try that here and with other sinister parts that sprout wings which take them to oblivion. I'll give it another shot tomorrow or Wednesday. Thanks again. Cheers.
There is a tool/s specifically for this spring but I made one out of a piece of peg wood. A hole drilled into the centre of the peg wood and three groves filed (i used a screw slotting file) for the prongs. Then just sit it on top of the spring and twist. If you do not have these tools just use fine tweezers to twist but have a piece of peg wood over the spring to catch the flyer.
5a5ddf2c010d5_ScreenShot2018-01-16at11_16_40.png.592ff5bffbf88c815ba1e0edc4200865.png
Thanks, Clockboy, I appreciate the heads up on the tools. I had seen them for sale over the years, but as I was into old pocket-watches,  I didn't have a use for them. Now I do.  And thanks for the pegwood idea as well.
BTW, I was looking at a book I have by Jendritzki last. Aside from it coincidentally containing a Wittnauer factory technical sheet for the model I worked on for my nephew last month, it had a page on KIF. While it is a different configuration, it might work. I definitely need to have more downward force, as the jewel seems to tip, making one side rise and increasing tension on the spring at that point. I'm attaching that Kif blurb. Thanks again. Cheers.
Oh, and if someone can instruct me on how to add to the technical data, I'm all eyes. I think the tech data I have for the Wittnauer 11K series could be of value. I already scanned it, but may have to do it again, as the files are too large, and my Paint program won't even open them. But I digress...Help here is appreciated.
Edited by MrRoundel
Correct spelling of author's name.
Have a coulpe of movement that has that type of spring also. Think one could be a FHF 96 and one is a EB or Baumgartner movement. I use a toothpick in the hole and then just spin the spring until it's sits right. Almost like a Seiko or Slava movement.
Try Gimp, free and good.
It is indeed an FHF/Std 96-4, branded Gruen. I'll try replacing the spring using a toothpick and/or narrowed/hollowed, pegwood. I hope it works, as the watch worked fine before I cleaned it. It just hadn't been serviced in many years, so I thought it a good idea. I lost the hole-jewel through an escape-hatch in my mechanical cleaner. I thought the Inca jewel might be a bit small to be save in there. Oh well...Thanks for your help, and the recommendation for Gimp. I'll check it out. Cheers.
Edited by MrRoundel
  • 11 months later...
Well, where does the time go anyway? I hope everyone's been well since my last check-in. It's been a while since I've worked on a watch, but the weather's keeping me indoors more, so I'm back at it a bit. Thank you all for your help so far.
I decided to take another go at this Gruen 505-6/ST 96-4 that I lost the jewel on. Using the working-through-plastic-bag and toothpick trick, I was able to get the upper Trishock spring in place, but the lower is still giving me fits. It just seems that the hole jewel I got from Cousins, Inca 711.11 either doesn't drop down far enough, or doesn't accommodate the present cap jewel. The combination seems to sit too high, which makes the angle too steep to get the spring arms in the recess. The top of the cap-jewel sits higher than the plane of the spring recess.
Is it possible that the ST 96-4 versions that utilize the Trishock spring rather than the Inca, use different sized jewels?  In looking for a parts movement, I notice that most of this model use the more common Incabloc shock system, not the Trishock. Any help is appreciated. Thanks ahead of time. Cheers.
Check my post titled removal, cleaning , installtion of jewels, to save the next spring.
The thread will continus showing techniques, just havn,t got a chance to get with it.
As for the lost part, a powerful magnet often finds it for you.
My cleaner was in an area that offered no hope for finding such a small part. Plus, it was a hole-jewel, which I should think is in a brass setting, so a magnet wouldn't help much. That said, was rather surprised that the brass colored shock springs seem to have enough iron in them to be attracted to a slightly magnetized screwdriver. Either that or there was some other sort of attraction taking place. I sure seemed magnetic.  So, yes, it seems that I could have used a magnet to find the shock spring I lost a while back.
Thanks for your response. Cheers.
Providing you are comfortable with balance complete removal, doing so would, Eleminate the risk of damaging the pivot as you push to get the spring installed. The bridge would be under your full control to a point you can get the task done without kif spring tool.
    • I was wondering because of the alum idea.
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
