My First Staking Set Advice
If you don't mind, ask them what happens if you don't dry run. Does the epilame still wear away, and if so, how quickly? What do they mean with "a surface tension measurement of epilame"? (It isn't a liquid.)
Hi V., This is not connected with the battery, the calendar switching movement is broken. Often the quartz calibres are not repairable, they are replaced if something is wrong. You need to understand what calibre is inside You watch, is it repairable or it will be easier/cheaper to replace the movement (or the entire watch). -
More eloquently put than i Stephen, although i dont think i was too far behind you 🙂. I received an email from Episurf, they dont provide specfic instructions for its application, but did tell me that some watchmakers use a dry rub method and others do not, also in their literature they provide a surface tension measurement of Epilame. -
They don't seem especially clogged not like teeth on a file, maybe a little but a good clean up will certainly improve them. That one in particular is unnamed but still seems fair condition, the others are really good quality, i think the seller was hoping for higher bids. No thats just staining Rich , the surface i would say are pretty even. Probably some discolouration from a metal it was used on. They all bite into spring steel nicely, better than buggering up a toothed file. The brands are from two reputable manufacturers. Thats a really good price . See how the bidding goes. -
Hi, I am in York so we are neighbours.🙂 Thanks for the replies this is a good place to be.🙂
