Early AS 976
Watchfixr
Had a very early AS 976 come in for service. I mean very early, blued steel hairspring and no cap jewel on the bridge escape wheel pivot. Put a little pressure on the 2nd wheel and it started to tick, so it needed service. I disassembled it, ran it through the ultrasonic, reassembled and lubricated. I always do a preliminary time and amplitude test before putting on the cannon pinion just in case I need to tear it down for some reason. Dial down, 276 degrees amplitude and 4 seconds fast. Dial up, it stopped! Repeated tests. Again, 276 degrees and 4 seconds fast dial down; stopped, dial up. Now, I know what is wrong, but I want opinions from the gallery. I figured it out in the middle of the night after I had stopped at that point. It is simple and easily missed!
Anyone want to offer an answer?
Ok, a lot of good thoughts. The end shake of the balance was ok. That's what baffled me.
The cause of the problem is the very end of the cock pivot is broken off. I missed it during examination of the wheels and pivots. Too complacent! With a high power loupe you can see the pivot is broken. the end shake was good because the remaining part of the pivot would fit into the hole jewel far enough to limit the shake. It also was long enough to allow good amplitude and timing when the balance was running on the other pivot (dial down). When I  inverted the movement, the pivot would bind because it is too short to reach the cap jewel.
This problem is somewhat rare, but I thought I would pass it along as a lesson for others. We never stop learning in this business.
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
