Early AS 976
Watchfixr
Had a very early AS 976 come in for service. I mean very early, blued steel hairspring and no cap jewel on the bridge escape wheel pivot. Put a little pressure on the 2nd wheel and it started to tick, so it needed service. I disassembled it, ran it through the ultrasonic, reassembled and lubricated. I always do a preliminary time and amplitude test before putting on the cannon pinion just in case I need to tear it down for some reason. Dial down, 276 degrees amplitude and 4 seconds fast. Dial up, it stopped! Repeated tests. Again, 276 degrees and 4 seconds fast dial down; stopped, dial up. Now, I know what is wrong, but I want opinions from the gallery. I figured it out in the middle of the night after I had stopped at that point. It is simple and easily missed!
Anyone want to offer an answer?
Ok, a lot of good thoughts. The end shake of the balance was ok. That's what baffled me.
The cause of the problem is the very end of the cock pivot is broken off. I missed it during examination of the wheels and pivots. Too complacent! With a high power loupe you can see the pivot is broken. the end shake was good because the remaining part of the pivot would fit into the hole jewel far enough to limit the shake. It also was long enough to allow good amplitude and timing when the balance was running on the other pivot (dial down). When I  inverted the movement, the pivot would bind because it is too short to reach the cap jewel.
This problem is somewhat rare, but I thought I would pass it along as a lesson for others. We never stop learning in this business.
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
