Crown under pressure
Hi all very very new to this. I have a couple of watches that I guess are over wound .now these are play watches for me to take apart and rebuild . The crown will turn less than a quarter and then returns to its previous position under load. What would the possible causes be.what should I look for while stripping . Neither have any complications
Hi there (from one newbie to another) It's very difficult to overwind a watch, you would have to put lots of pressure on the winder to rip the mainspring from the wall of the barrel. The usual reason is the watch has already been wound up but won't work because it generally needs cleaning and has given up the ghost.
There are lots of lovely videos to get you started on your own watch with a handful of tools to start. Good luck
Edited by OCSfan
Predicted text
At the rate I’m buying tools I could have purchased the watch I really want . The broken watch is a little smiths astral. Looked bigger in the picture . Likes Luke a nightmare to practice on. Hey ho . Here we go
Look for them to simply be watches that aren’t running, usually from lack of service but any other reason is possible. Technically there is no such thing as overwound. What happens is a watch quits running and everyone who picks it up tries to wind it, and eventually it is wound as tight as it can be. Then later someone picks it up and thinks , oh, it’s overwound and that wasn’t the case. Make sense?
Sent from my iPad using Tapatalk Pro
What movements do these watches have ? Most movements can have the mainspring release its power reserve. You have to do it gently and the way you do it depends for many movements.
This is the Ops movement. Can't identify it but looks a pretty standard affair. Release by lifting the click and letting fitted crown and stem revolve between finger and thumb slowly until mainspring is unwound or use a well fitting screwdriver on the mainspring wheel until unwound.
Really suggest the OP goes on YouTube first and find some videos of this being done before attempting themself. a18213b9e0f68c0ef7b6cd2ae8307f62.jpg
Sent from my SM-T585 using Tapatalk
It should be stressed this is often tricky (you can think you have a good grip on the crown or what have you and it starts turning and unwinding rapidly when you least expect it) and if too much power is let down too quickly it can cause damage to the movement. That being said it is 'simple' and a key thing you need to practice in watch repair, always make sure the mainspring is let down before starting any disassembly. Good luck.
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
